Posted: Tue Jun 19, 2007 3:42 pm |
The closest I have to your version is PCM vs. 4.014. I was able to
make it work with that version. See the test program shown below.
The key point is that you have to put in code to make the additional PWM
pins into output pins. The compiler doesn't do it for you automatically.
This is shown in the code.
#include <16F690.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOMCLR
#use delay(clock=8000000)
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
setup_timer_2(T2_DIV_BY_16, 124, 1); // 1000 Hz
set_pwm1_duty(31); // 25% duty cycle
// Enable PWM pins P1B, P1C, and P1D for output.
// Note: P1A is done by the compiler.
output_low(P1B);
output_low(P1C);
output_low(P1D);
// Steer the PWM output to all four P1x pins.
setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A
| CCP_PULSE_STEERING_B
| CCP_PULSE_STEERING_C
| CCP_PULSE_STEERING_D );
ymoona
Joined: 20 Mar 2005 Posts: 32 Location: Heiloo, the Netherlands
Posted: Sun Jun 24, 2007 12:14 pm |
PCM programmer wrote: | The closest I have to your version is PCM vs. 4.014. I was able to
#include <16F690.h>
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
output_low(P1B);
output_low(P1C);
output_low(P1D);
thanks!! that did the trick. But is seems to have a problem with the while loop Ive wrote.
while(1){
setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A );
output_high( led );
delay_ms(2000);
// left wheels backward, right wheels not moving
setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_B );
output_low( led );
delay_ms(2000);
The problem is that the first time this loop is passed. Every thing is ok. but the second time the left wheels only steer backwards, changing from 100% to 25% duty. _________________ checkout my site: www.ymoona.com/wiki |
Posted: Sun Jun 24, 2007 12:28 pm |
Post a test program similiar to the one that I did, except that it has your
loop code in it. Make sure the program is compilable. For example,
the LED pin must be defined.
Also, you have the P1A, P1B, etc. outputs attached to wheel motors.
Post a list of which output pin drives which motor. i.e., P1A is the left
motor, etc. In other words, post a full explanation. |
ymoona
Posted: Sun Jun 24, 2007 1:34 pm |
this is the code I currently use:
#include <16F690.h>
#device adc=8
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,force_hw,address=0x00110011)
Pin defines
#define led PIN_A5
#define driver_a PIN_C0
#define driver_b PIN_C1
Variables
Function prototypes
void set_drivers( int1 value );
#int_SSP // i2c activty
SSP_isr()
return;
void main(){
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
//setup_timer_2(T2_DIV_BY_1,255,1);
//enable_interrupts(INT_SSP);
//enable_interrupts(GLOBAL);
setup_oscillator(OSC_8MHZ);
set_drivers( true );
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
output_high( led );
output_low( led );
output_high( led );
output_low( led );
while(1){
// left wheel foreward, right wheels not moving
output_high( led );
output_low( led );
Funtion boddies
void set_drivers( values ){
if( values ){
output_high( driver_a );
output_high( driver_b );
else{
output_low( driver_a );
output_low( driver_b );
for hardware I use a l298(a dual H-bridge)
l298 input1 -> RC2 D
l298 input2 -> RC3 C
l298 input3 -> RC4 B
l298 input4 -> RC5 A
the driver enable pins are also connected.
note: when I drive de motors without PWM the dual H-Bridge setup works just fine. Tested with the following code:
while(1){
output_high( PIN_A5 );
// drive motor A
output_low( PIN_C3 );
output_high( PIN_C2 );
// drive motor B
output_low( PIN_C4 );
output_high( PIN_C5 );
delay_ms(5000);
output_low( PIN_A5 );
// driver motor A
output_low( PIN_C2 );
output_high( PIN_C3 );
// driver motor Ab output_low( PIN_C5 );
output_high( PIN_C4 );
delay_ms(5000);
Posted: Sun Jun 24, 2007 1:43 pm |
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2); |
You're using software i2c on the same pins that you're using for your motor driver.
The 16F690 does have hardware i2c pins, but they're on pins B4 and B6,
not C4 and C3. |
ymoona
Posted: Sun Jun 24, 2007 1:55 pm |
PCM programmer wrote: | Quote: |
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
not C4 and C3. |
thanks! stupid me! but it not the solution for my problem :(
any other ideas? this is the current software
#include <16F690.h>
#device adc=8
Pin defines
#define led PIN_A5
Variables
Function prototypes
SSP_isr()
return;
void main(){
setup_adc(ADC_OFF);
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
output_high( led );
output_low( led );
output_high( led );
output_low( led );
while(1){
output_high( led );
output_low( led );
Funtion boddies
if( values ){
else{
Posted: Sun Jun 24, 2007 2:43 pm |
I was able to fix it by adding the line shown in bold below.
Also, it's best to define a symbolic name for the PWM pins.
If you use "PIN_C4", etc., as the pin name in your code, it doesn't
really tell you anything. You have to remember that it's the P1B
pin of the PWM module. You could also make a mistake and type
in the wrong pin. But if you see "P1B" as the pin, you know its the
"B" output of the PWM module. "PIN_C4" is basically a "magic number"
when you use it in your code. In C, the concept of "magic number"
means a number that has a special meaning, but it's known only to
the original programmer, and he might forget it someday. Then it
bites him (as well as some future maintenance programmer).
Add the line shown in bold below:
Quote: |
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
while(1){
// left wheel forward, right wheels not moving
output_low(P1B);
output_high( led );
output_low( led );
ymoona
Posted: Mon Jun 25, 2007 9:50 am |
PCM programmer wrote: | I was able to fix it by adding the line shown in bold below.
Quote: |
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
while(1){
output_low(P1B);
output_high( led );
output_low( led );
thanks now it work well! _________________ checkout my site: www.ymoona.com/wiki |
