16F690 pulse steering, 4 pin PWM
Goto page 1, 2  Next
ymoona
PostPosted: Mon Jun 18, 2007 8:32 am     Reply with quote
I´m trying to get my dual motor driver to work. I found on the microchip site that the 16f690 has 4 PWM channels.
How do I get them to work? So far I got only RC2 ( PIN 14) to generate a PWM signal. How does the pulse steering work?
I´m using an l298. I connected C2, C3, C4, C5 to input 1 till 4 of the dual motor driver.
How do I get controll of the 4 pwm channels?
checkout my site: www.ymoona.com/wiki
PostPosted: Mon Jun 18, 2007 9:28 am     Reply with quote
MicroChip, seem determined to annoy people with their nomenclature on the PWMs....
The 690, only has _one_ PWM. It has options to route it's output to four pins, in different drive modes (for half bridge, and full bridge drive of a single motor), but it is not capable of giving you two distinct PWM trains, to drive two motors. :(
ymoona
PostPosted: Mon Jun 18, 2007 9:33 am     Reply with quote
Thanks, so it has only one PWM. But it can be routed to one ore _multiple_ pins. How do I set this up?
PostPosted: Mon Jun 18, 2007 10:19 am     Reply with quote
OK.
In the .h file for the processor, there should be defines for the pwm setup, giving:
#define CCP_PWM_H_H                     0x0c
#define CCP_PWM_H_L                     0x0d
#define CCP_PWM_L_H                     0x0e
#define CCP_PWM_L_L                     0x0f
#define CCP_PWM_FULL_BRIDGE             0x40
#define CCP_PWM_FULL_BRIDGE_REV         0xC0
#define CCP_PWM_HALF_BRIDGE             0x80
#define CCP_PULSE_STEERING_A            0x01000000
#define CCP_PULSE_STEERING_B            0x02000000
#define CCP_PULSE_STEERING_C            0x04000000
#define CCP_PULSE_STEERING_D            0x08000000
You 'OR' these with the CCP_PWM setup, to give the required behaviours. You can feed the single PWM, to any of the four output pins with the last four commands, or to multiple pins, in the half bridge/full bridge patterns with the middle three commands. The top four, control the output polarity.
ymoona
PostPosted: Mon Jun 18, 2007 2:09 pm     Reply with quote
I found the these constands in the header file for my PIC.
But I only get pin A to work, this is the code I used:
 setup_ccp1(CCP_PWM);
   set_pwm1_duty(100);
   while(1){
      output_high( led );
      setup_ccp1( CCP_PULSE_STEERING_A | CCP_PWM_L_H );
      setup_ccp1( CCP_PULSE_STEERING_A |CCP_PWM_L_H);
      setup_ccp1( CCP_PULSE_STEERING_A |CCP_PWM_H_L);
      setup_ccp1( CCP_PULSE_STEERING_A | CCP_PWM_L_L);
      output_low( led );
      setup_ccp1( CCP_PULSE_STEERING_B | CCP_PWM_L_H );
      setup_ccp1( CCP_PULSE_STEERING_B |CCP_PWM_L_H);
      setup_ccp1( CCP_PULSE_STEERING_B |CCP_PWM_H_L);
      setup_ccp1( CCP_PULSE_STEERING_B | CCP_PWM_L_L);
      output_high( led );
      setup_ccp1( CCP_PULSE_STEERING_C | CCP_PWM_L_H );
      setup_ccp1( CCP_PULSE_STEERING_C |CCP_PWM_L_H);
      setup_ccp1( CCP_PULSE_STEERING_C |CCP_PWM_H_L);
      setup_ccp1( CCP_PULSE_STEERING_C | CCP_PWM_L_L);
      output_low( led );
      setup_ccp1( CCP_PULSE_STEERING_D | CCP_PWM_L_H );
      setup_ccp1( CCP_PULSE_STEERING_D |CCP_PWM_L_H);
      setup_ccp1( CCP_PULSE_STEERING_D |CCP_PWM_H_L);
      setup_ccp1( CCP_PULSE_STEERING_D | CCP_PWM_L_L);
      output_high( led );
What is going wrong? Only PinA is showing activity, the other pins are completely dead!
I´m not sure what the following defines mean, how do they help me
I want 1 PWM signal splitted over ONE or MULTIPLE pins, How should I do this?
PostPosted: Mon Jun 18, 2007 3:17 pm     Reply with quote
Look at the data sheet.
The defines exactly correspond to the configuration bits in the registers for the PWM. So:
1100 = PWM mode; P1A, P1C active-high; P1B, P1D active-high
1101 = PWM mode; P1A, P1C active-high; P1B, P1D active-low
1110 = PWM mode; P1A, P1C active-low; P1B, P1D active-high
1111 = PWM mode; P1A, P1C active-low; P1B, P1D active-low
Correspond to the first four defines.
Then read the maual for SETUP_CCP1, and realise that for the ECCP, you need _two_ parameters...
setup_ccp1(CCP_PWM, CCP_PWM_H_H |CCP_PULSE_STEERING_B);
Beware that the steering only works in single output mode.
ymoona
PostPosted: Tue Jun 19, 2007 11:21 am     Reply with quote
But I dont want single output, I want multiple output.
setup_ccp1(CCP_PWM, CCP_PWM_H_H |CCP_PULSE_STEERING_B); doesnt work. I get an compiler error: Expecting a close paren. What is going wrong here?
PostPosted: Tue Jun 19, 2007 12:34 pm     Reply with quote
Post your compiler version.
ymoona
PostPosted: Tue Jun 19, 2007 2:19 pm     Reply with quote
IDE 4.013
PCM 4.013
PCM 4.013
PCH 4.013
PostPosted: Tue Jun 19, 2007 3:42 pm     Reply with quote
The closest I have to your version is PCM vs. 4.014. I was able to
make it work with that version. See the test program shown below.
The key point is that you have to put in code to make the additional PWM
pins into output pins. The compiler doesn't do it for you automatically.
This is shown in the code.
#include <16F690.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOMCLR
#use delay(clock=8000000)
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
setup_timer_2(T2_DIV_BY_16, 124, 1);  // 1000 Hz
set_pwm1_duty(31);  // 25% duty cycle
// Enable PWM pins P1B, P1C, and P1D for output.
// Note:  P1A is done by the compiler.
output_low(P1B);
output_low(P1C);
output_low(P1D);
// Steer the PWM output to all four P1x pins.
setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A
                       | CCP_PULSE_STEERING_B
                       | CCP_PULSE_STEERING_C
                       | CCP_PULSE_STEERING_D );
ymoona
PostPosted: Sun Jun 24, 2007 12:14 pm     Reply with quote
#include <16F690.h>
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
output_low(P1B);
output_low(P1C);
output_low(P1D);
thanks!! that did the trick. But is seems to have a problem with the while loop Ive wrote.
  while(1){
      setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A );
      output_high( led );
      delay_ms(2000);
      // left wheels backward, right wheels not moving
      setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_B );
      output_low( led );
      delay_ms(2000);
The problem is that the first time this loop is passed. Every thing is ok. but the second time the left wheels only steer backwards, changing from 100% to 25% duty.
PostPosted: Sun Jun 24, 2007 12:28 pm     Reply with quote
Post a test program similiar to the one that I did, except that it has your
loop code in it. Make sure the program is compilable. For example,
the LED pin must be defined.
Also, you have the P1A, P1B, etc. outputs attached to wheel motors.
Post a list of which output pin drives which motor. i.e., P1A is the left
motor, etc. In other words, post a full explanation.
ymoona
PostPosted: Sun Jun 24, 2007 1:34 pm     Reply with quote
this is the code I currently use:
#include <16F690.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,force_hw,address=0x00110011)
Pin defines
#define led      PIN_A5
#define driver_a PIN_C0
#define driver_b PIN_C1
Variables
Function prototypes
void set_drivers( int1 value );
#int_SSP // i2c activty
SSP_isr()
   return;
void main(){
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   //setup_timer_2(T2_DIV_BY_1,255,1);
   //enable_interrupts(INT_SSP);
   //enable_interrupts(GLOBAL);
   setup_oscillator(OSC_8MHZ);
   set_drivers( true );
   output_low(PIN_C5);
   output_low(PIN_C4);
   output_low(PIN_C3);
   output_low(PIN_C2);
    output_high( led );
    output_low( led );
    output_high( led );
    output_low( led );
   while(1){
      // left wheel foreward, right wheels not moving
      output_high( led );
      output_low( led );
Funtion boddies
void set_drivers( values ){
   if( values ){
      output_high( driver_a );
      output_high( driver_b );
   else{
      output_low( driver_a );
      output_low( driver_b );
for hardware I use a l298(a dual H-bridge)
l298 input1 -> RC2 D
l298 input2 -> RC3 C
l298 input3 -> RC4 B
l298 input4 -> RC5 A
the driver enable pins are also connected.
note: when I drive de motors without PWM the dual H-Bridge setup works just fine. Tested with the following code:
 while(1){
      output_high( PIN_A5 );
      // drive motor A
      output_low( PIN_C3 );
      output_high( PIN_C2 );
      // drive motor B
      output_low( PIN_C4 );
      output_high( PIN_C5 );
      delay_ms(5000);
      output_low( PIN_A5 );
      // driver motor A
      output_low( PIN_C2 );
      output_high( PIN_C3 );
      // driver motor Ab      output_low( PIN_C5 );
      output_high( PIN_C4 );
      delay_ms(5000);
PostPosted: Sun Jun 24, 2007 1:43 pm     Reply with quote
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
You're using software i2c on the same pins that you're using for your motor driver.
The 16F690 does have hardware i2c pins, but they're on pins B4 and B6,
not C4 and C3.
ymoona
PostPosted: Sun Jun 24, 2007 1:55 pm     Reply with quote
output_low(PIN_C5);
output_low(PIN_C4);
output_low(PIN_C3);
output_low(PIN_C2);
not C4 and C3.
thanks! stupid me! but it not the solution for my problem :(
any other ideas? this is the current software
#include <16F690.h>
#device adc=8
Pin defines
#define led      PIN_A5
Variables
Function prototypes
SSP_isr()
   return;
void main(){
   setup_adc(ADC_OFF);
   output_low(PIN_C5);
   output_low(PIN_C4);
   output_low(PIN_C3);
   output_low(PIN_C2);
    output_high( led );
    output_low( led );
    output_high( led );
    output_low( led );
   while(1){
      output_high( led );
      output_low( led );
Funtion boddies
   if( values ){
   else{
Goto page 1, 2  Next
Page 1 of 2
