Posted: Thu Apr 06, 2006 6:13 pm |
| Quote: | | My compiler version is 3.147 |
I looked at the .LST file for your version, and the problem is that it
doesn't create a hardware UART on pins B5 and B2. It creates a
software UART. This means you will not get an RDA interrupt.
This thread discusses the problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=19455
I tried the suggestion in that thread to use pins C6 and C7 and
it doesn't appear to work with your version. The compiler just
gives an error message. If you have PCW maybe you can fix it,
or you may have to upgrade. |
Posted: Thu Apr 06, 2006 10:24 pm |
If you don't PCW or PCWH, then you don't have the Device Editor
and you don't have the possibility of fixing it by editing the device file.
If so, then here is a demo program that shows how to make your own
putc() and get() routines if the CCS library code doesn't work.
To use this code, you enter the crystal frequency and the UART baud
rate in the #define statements below. At the start of main(), you call
the init_uart() function. Then use my_putc() to send a character and
my_getc() to receive a character. You can use printf() if you use the
re-direction feature to send output to the my_putc() routine.
The demo program below shows how to do that.
#include <16F87.H>
#define FREQ_OSC 10000000
#define BAUD_RATE 4800
#use delay(clock = FREQ_OSC)
#byte PIR1 = 0x0c
#byte SPBRG = 0x99
#byte RCSTA = 0x18
#byte TXREG = 0x19
#byte RCREG = 0x1A
#byte TXSTA = 0x98
#bit TXIF = PIR1.4
#bit RCIF = PIR1.5
#bit CREN = RCSTA.4
// Wait for the hardware UART's transmitter
// to become ready and then send the specified
// character.
void my_putc(char c)
while(!TXIF);
TXREG = c;
// Wait for character to be available from the
// hardware UART's receiver and then return it.
// If there is an overrun error, then clear it.
char my_getc(void)
int temp;
int retval;
while(!RCIF);
temp = RCSTA;
retval = RCREG;
if(bit_test(temp, 1))
CREN = 0;
CREN = 1;
return(retval);
void init_uart(void)
SPBRG = (FREQ_OSC / (BAUD_RATE * 16)) -1;
TXSTA = 0x26;
RCSTA = 0x90;
char c;
init_uart();
printf(my_putc, "Hello World\n\r");
c = my_getc(); // Get a char and echo it back
my_putc(c);
If you want to test receiver interrupts, then substitute
the following code for the bottom part of the program.
| Code: | #int_rda
void rda_isr(void)
char c;
c = my_getc();
my_putc(c);
init_uart();
enable_interrupts(INT_RDA);
PICman
Posted: Fri Jul 31, 2009 2:29 pm |
Thank you VERY MUCH PCM programmer !!!
I had a real problem trying to activate the silicon UART on a PIC16F88.
I started to read here and there and, - BOY - , I was discouraged to see - NOT AGAIN - a version issue !!!!
But I finally found your "manual override" code (INIT_UART, MY_GETC and MY_PUTC) and BINGO ! Everything worked perfectly !!!!
Again thank you ! _________________ The ideal electronic world: A place where the words VERSION and REVISION do NOT exist ! |
muratmaman
Posted: Mon Nov 08, 2010 3:21 am |
| PICman wrote: | Thank you VERY MUCH PCM programmer !!!
Again thank you ! |
I used to pic 16f886 that my problem i can not use same time INT_RDA and INT_RB, INT_TIMER1. INT_RDA works alone and INT_RB, INT_TIMER1 works alone as well. But when i would want to use all of them same time it does not works. What can be source of problem. _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Mon Nov 08, 2010 3:31 am |
You are spending too long in one or more of the interrupt handlers.
Remember that things like timer interrupts, INT_RDA, etc., reflect hardware events happening at intervals. You need to always handle the event, and get out _fast_, then do any processing in the main code, so that other events can be handled. In the example code here, simply the act of sending the byte 'out' again on a software UART, _will_ take as long as it takes for another character to arrive, so if the GPS sends reasonably fast, there will never be time to do anything else.....
muratmaman
Posted: Mon Nov 08, 2010 5:38 am |
| Ttelmah wrote: | You are spending too long in one or more of the interrupt handlers.
Could you please check my code and give me idea.
http://www.ccsinfo.com/forum/viewtopic.php?t=43833 _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Mon Nov 08, 2010 5:45 am |
No, because the problem will be in one (or more) of the interrupt handlers, which you don't show.
muratmaman
Posted: Mon Nov 08, 2010 6:04 am |
| Ttelmah wrote: | No, because the problem will be in one (or more) of the interrupt handlers, which you don't show.
#include "16f886.h"
#device *=16 ADC=10
#fuses INTRC_IO,NOWDT,NOPROTECT,NOPUT,NOLVP,NOFCMEN,NOMCLR, BROWNOUT // with internal oscillator
#use rs232(baud=9600,uart1, parity=N, xmit=PIN_C6,rcv=PIN_C7, bits=8, errors, timeout=500, STREAM=ENCODER)
#byte PIE1 = 0x8c
#byte INTCON = 0x8b
//BYTE data[15]={0};
BYTE i = 0;
#INT_RDA
void RS232(void)
data[i] = getc();
#INT_EXT
void ext_isr()
if (!input(PIN_B0) )
// Interrupts are checked 6ms after to filter noise
delay_6ms();
#INT_TIMER1
void timer1_isr()
bit_set(int_events, event_int_timer1);
short bResult;
disable_interrupts(GLOBAL);
output_a(0b00000000); // motor pinleri A2 ve A3 1 olacak
output_b(0b00000001); // RB0(CRD_CON), RB4(ortak uç), RB5(switch), RB6(Manuel kilit), RB7(Kapı açık kapalı)
output_c(0b10011011); // RC7 (RX input), RC6 (TX output), RC3(SCL), RC4(SDA), RC5(motor pin output ), RC2 Buzzer, RCO ve RC1 saat içininput
output_e(0x00);
set_tris_a(0b00000000);
set_tris_b(0b00000001); // RB0(CRD_CON), RB4(ortak uç), RB5(switch), RB6(Manuel kilit), RB7(Kapı açık kapalı), RC2 Buzzer,
set_tris_c(0b10011011); // RC7 (RX input), RC6 (TX output), RC3(SCL), RC4(SDA), RC5(motor pin output ), RCO ve RC1 saat içininput
set_tris_e(0x00);
port_b_pullups(TRUE);
setup_adc_ports( sAN0|VSS_VDD );
set_adc_channel(1);
setup_spi(FALSE);
setup_timer_1(T1_EXTERNAL|T1_CLK_OUT|T1_DIV_BY_1); // setup interrupts
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_oscillator(osc_4mhz);
last_port_b = input_b();
bNotSleep = 1;
// Enable interrupts
enable_interrupts(INT_RB);
enable_interrupts(INT_EXT);
SET_TIMER1(0);
#ignore_warnings 203
bNotSleep = 0;
#ignore_warnings none
sleep();
#asm
nop
#endasm
[quote]
Could you please rewiew and give me ide how can handle time on this code.[/quote] |
Posted: Mon Nov 08, 2010 7:32 am |
So, where are the other handlers?.
You must _never_ enable an interrupt without a handler for that interrupt present. INT_RB, and INT_RDA in particular, _must_ perform the operations to reset the hardware event that triggered them (read port B, and fetch a character from the UART), or they will trigger _for ever_, and lock the processor.
What you have poster _will_ hang.
muratmaman
Posted: Sat Nov 13, 2010 7:59 am |
| Ttelmah wrote: | So, where are the other handlers?.
What do you mean? I can understand. Could you please explanin with example? _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
FvM
Posted: Sat Nov 13, 2010 8:38 am |
| Your latest code has an #INT_RDA handler, but is missing #INT_RB, which must be expected to cause your application to hang. The #INT_RDA is performing getc(), as required, but it most likely should also increment the buffer pointer i (and do additional things that you'll need for a buffered receive operation). |
muratmaman
Posted: Sat Nov 13, 2010 1:26 pm |
| FvM wrote: | | Your latest code has an #INT_RDA handler, but is missing #INT_RB, which must be expected to cause your application to hang. The #INT_RDA is performing getc(), as required, but it most likely should also increment the buffer pointer i (and do additional things that you'll need for a buffered receive operation). |
#include "16f886.h"
#device *=16 ADC=10
#use delay(clock=8000000)
#use rs232(baud=9600, parity=N, xmit=PIN_C6,rcv=PIN_C7, bits=8)
#include "main.h"
#include "bcd.c"
#include "DateTime.c"
#include "Events.c"
#define event_int_timer1 1
BYTE i = 0;
unsigned char eeprom_buffer[32]; // Used for local storage data (EEPROM)
char last_port_b;
long timeout;
unsigned char _ServiceType;
#int_RB
void RB_isr(void)
char port_b;
char changes;
port_b = input_b();
changes = last_port_b ^ port_b;
last_port_b = port_b;
if ( bit_test(changes,7) && !bit_test(last_port_b,7) ) // High to Low on B7
if ( !input(PIN_B7) ){
// do something
return;
#int_RDA
void RDA_isr(void)
while(!kbhit()&&(++timeout<50000)) // 1/2 second
delay_us(10);
if(kbhit()){
eeprom_buffer[i] = getc();
if ( eeprom_buffer[i] == 0x13 ){
_ServiceType = eeprom_buffer[1];
i++;
}else{
memset(eeprom_buffer, 0x00, sizeof(eeprom_buffer));
_ServiceType = 0x00;
i = 0;
#INT_EXT
void ext_isr()
// do something
#INT_TIMER1
void timer1_isr()
#define RED_LED PIN_A7
#define BLUE_LED PIN_A6
#define GREEN_LED PIN_A5
void BlinkRed(int16 nStop ){
output_high(RED_LED);
delay_ms(nStop);
output_low(RED_LED);
void BlinkBlue(){
output_high(BLUE_LED);
output_low(BLUE_LED);
void BlinkGreen(int16 nStop){
output_high(GREEN_LED);
delay_ms(nStop);
output_low(GREEN_LED);
output_e(0x00);
set_tris_e(0x00);
set_adc_channel(1);
setup_spi(FALSE);
ext_int_edge(0, H_TO_L); // sinyalin dü?en kenarynda kesme olursa interrup olsun (High to Low dü?en kenarda interrup olursa active ol)
setup_oscillator(osc_8mhz);
SET_TIMER1(0); // adjust the real time clock
enable_interrupts(INT_TBE);
i = 0; // Serail data counter. It was defined at the rs232.
BlinkGreen(1000);
sleep();
I have rewrite my acode acording to your insruction, however again it could not enter INT_RB, INT_TIMER1, INT_EXT.
You can see that when i enable all of interrupts it could not came BlinkGreen(1000);
If I disable enable_interrupts(INT_TBE); this code those interrupts (
INT_RB, INT_TIMER1, INT_EXT) are working.
I have changed according to your ex comment add SAMPLE_EARLY but did not change anything.
What can be source of problem ? _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Sat Nov 13, 2010 1:56 pm |
First, get rid of most of your RDA code.
1) You do not need to test if a character is available, if the interrupt occurs, one _is_.
2) Do _not_ write the the EEPROM in the interrupt. The EEPROM write, takes typically 4mSec. Characters can arrive at just over 1mSec intervals. Delaying in the interrupt for an EEPROM write _will_ overflow the UART. Repeat fifty times, the mantra - _KEEP INTERRUPT HANDLERS FAST, UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING_ - You don't...
3) _Always_ have ERRORS in the UART declaration for he hardware UART. The _only_ occasion not to have this, is if _you_ are handling UART errors. Without this, if the UART overflows, the chip _will_ hang.
muratmaman
Posted: Sat Nov 13, 2010 2:48 pm |
| Ttelmah wrote: | First, get rid of most of your RDA code.
Thanks for your comment.
#use rs232(baud=9600, parity=N, xmit=PIN_C6,rcv=PIN_C7, bits=8, ERRORS)
#int_RDA
void RDA_isr(void)
buffer[i] = getc();
if ( buffer[i] == 0x13 ){
_ServiceType = buffer[1];
I changed my code according to your comment. But did not change anything. If you check my code can comment anything about WHY BlinkGreen(1000) is not working. When i enable INT_TBE it is not going to forward. 16886 Interrupt system does not support FAST, HIGH. After INT_RDA complete it is not going to in the sleep(). _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
FvM
Posted: Sun Nov 14, 2010 3:43 am |
I notice that you're applying arbitrary changes to your code, fixing some bugs and add new at other places, one step forward and two steps back.
Previously you had int_rb enabled without an #int_rb handler. Now you have added int_tbe, but are missing the #int_tbe handler. What is next?
It's effectively impossible to help in this situation. |
