#INT_RDA and PIC16F87
Goto page Previous  1, 2
PostPosted: Mon Nov 08, 2010 7:32 am     Reply with quote
So, where are the other handlers?.
You must _never_ enable an interrupt without a handler for that interrupt present. INT_RB, and INT_RDA in particular, _must_ perform the operations to reset the hardware event that triggered them (read port B, and fetch a character from the UART), or they will trigger _for ever_, and lock the processor.
What you have poster _will_ hang.
muratmaman
PostPosted: Sat Nov 13, 2010 7:59 am     Reply with quote
What do you mean? I can understand. Could you please explanin with example?
I have been developing pic and other microcontroller. I would want to share and get experiment form this site
FvM
PostPosted: Sat Nov 13, 2010 8:38 am     Reply with quote
Your latest code has an #INT_RDA handler, but is missing #INT_RB, which must be expected to cause your application to hang. The #INT_RDA is performing getc(), as required, but it most likely should also increment the buffer pointer i (and do additional things that you'll need for a buffered receive operation).
muratmaman
PostPosted: Sat Nov 13, 2010 1:26 pm     Reply with quote
#include "16f886.h"
#device *=16 ADC=10
#fuses INTRC_IO,NOWDT,NOPROTECT
#use delay(clock=8000000)
#use rs232(baud=9600, parity=N, xmit=PIN_C6,rcv=PIN_C7, bits=8)
#include "main.h"
#include "bcd.c"
#include "DateTime.c"
#include "Events.c"
#define event_int_timer1         1
BYTE i = 0;
unsigned char eeprom_buffer[32];      // Used for local storage data (EEPROM)
char       last_port_b;
long timeout;
unsigned char   _ServiceType;
#int_RB
void  RB_isr(void)
   char port_b;
   char changes;
   port_b = input_b();
   changes = last_port_b ^ port_b;
   last_port_b = port_b;
   if ( bit_test(changes,7) && !bit_test(last_port_b,7) )   // High to Low on B7
      if ( !input(PIN_B7) ){
         // do something
       return;
#int_RDA
void  RDA_isr(void)
   while(!kbhit()&&(++timeout<50000)) // 1/2 second
    delay_us(10);
    if(kbhit()){
      eeprom_buffer[i] = getc();
       if ( eeprom_buffer[i] == 0x13 ){
         _ServiceType = eeprom_buffer[1];
       i++;
    }else{
       memset(eeprom_buffer, 0x00, sizeof(eeprom_buffer));
      _ServiceType = 0x00;
      i = 0;
#INT_EXT
void ext_isr()
   if (!input(PIN_B0) )
      // do something
#INT_TIMER1
void timer1_isr()
   bit_set(int_events, event_int_timer1);
#define RED_LED         PIN_A7
#define BLUE_LED        PIN_A6
#define GREEN_LED       PIN_A5
void BlinkRed(int16 nStop ){
   output_high(RED_LED);
   delay_ms(nStop);
   output_low(RED_LED);
void BlinkBlue(){
   output_high(BLUE_LED);
   output_low(BLUE_LED);
void BlinkGreen(int16 nStop){
   output_high(GREEN_LED);
   delay_ms(nStop);
   output_low(GREEN_LED);
     disable_interrupts(GLOBAL);
   output_a(0b00000000);
   output_b(0b00000001);
   output_c(0b10011011);
   output_e(0x00);
   set_tris_a(0b00000000);
   set_tris_b(0b00000001);
   set_tris_c(0b10011011);
   set_tris_e(0x00);
   port_b_pullups(TRUE);
   setup_adc_ports( sAN0|VSS_VDD );
   set_adc_channel(1);
   setup_spi(FALSE);
   setup_timer_1(T1_EXTERNAL|T1_CLK_OUT|T1_DIV_BY_1);   // setup interrupts
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   ext_int_edge(0, H_TO_L); // sinyalin dü?en kenarynda kesme olursa interrup olsun (High to Low dü?en kenarda interrup olursa active ol)
   setup_oscillator(osc_8mhz);
   last_port_b = input_b();
   SET_TIMER1(0); // adjust the real time clock
    enable_interrupts(INT_RB);
    enable_interrupts(INT_EXT);
    enable_interrupts(INT_RDA);
    enable_interrupts(INT_TBE);
    i = 0; // Serail data counter. It was defined at the rs232.
   BlinkGreen(1000);
#ignore_warnings 203
      sleep();
I have rewrite my acode acording to your insruction, however again it could not enter INT_RB, INT_TIMER1, INT_EXT.
You can see that when i enable all of interrupts it could not came BlinkGreen(1000);
If I disable enable_interrupts(INT_TBE); this code those interrupts (
INT_RB, INT_TIMER1, INT_EXT) are working.
I have changed according to your ex comment add SAMPLE_EARLY but did not change anything.
What can be source of problem ?
PostPosted: Sat Nov 13, 2010 1:56 pm     Reply with quote
First, get rid of most of your RDA code.
1) You do not need to test if a character is available, if the interrupt occurs, one _is_.
2) Do _not_ write the the EEPROM in the interrupt. The EEPROM write, takes typically 4mSec. Characters can arrive at just over 1mSec intervals. Delaying in the interrupt for an EEPROM write _will_ overflow the UART. Repeat fifty times, the mantra - _KEEP INTERRUPT HANDLERS FAST, UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING_ - You don't...
3) _Always_ have ERRORS in the UART declaration for he hardware UART. The _only_ occasion not to have this, is if _you_ are handling UART errors. Without this, if the UART overflows, the chip _will_ hang.
muratmaman
PostPosted: Sat Nov 13, 2010 2:48 pm     Reply with quote
Thanks for your comment.
#use rs232(baud=9600, parity=N, xmit=PIN_C6,rcv=PIN_C7, bits=8, ERRORS)
#int_RDA
void  RDA_isr(void)
      buffer[i] = getc();
       if ( buffer[i] == 0x13 ){
         _ServiceType = buffer[1];
I changed my code according to your comment. But did not change anything. If you check my code can comment anything about WHY BlinkGreen(1000) is not working. When i enable INT_TBE it is not going to forward. 16886 Interrupt system does not support FAST, HIGH. After INT_RDA complete it is not going to in the sleep().
FvM
PostPosted: Sun Nov 14, 2010 3:43 am     Reply with quote
I notice that you're applying arbitrary changes to your code, fixing some bugs and add new at other places, one step forward and two steps back.
Previously you had int_rb enabled without an #int_rb handler. Now you have added int_tbe, but are missing the #int_tbe handler. What is next?
It's effectively impossible to help in this situation.
muratmaman
PostPosted: Sun Nov 14, 2010 4:15 am     Reply with quote
Thanks for your comment. I would want to say that if i did not put #int_tbe and did not enable it was not working INT_RBA interrupt.
At the present i deleted the #int_tbe however does not change anything. In this situation INT_RDA interrupt does not work. If you can send me very simple program with INT_RDA, INT_RB, INT_TIMER1, INT_EXT. I will appreciate.
PostPosted: Sun Nov 14, 2010 9:41 am     Reply with quote
I'd suspect you almost certainly have hardware problems that need to be fixed, before you have a hope of getting code to work.
1) When you are operating LED's, have you got current limiting resistors in series?.
2) On a 'flash LED' test, check the timing. Do you get the right number of flashes in a minute?.
3) Is the input serial line sitting 'high' when no data is arriving? - if not, the code won't work.
4) If you have an external interrupt in use, is the line feeding this sitting at the correct 'idle' level, when no interrupt is present? - so if you are using H_TO_L is it sitting _above_ the PIC's 'high' input level when no interrupt is occurring, or for L_TO_H, is it sitting below the low level?.
Then, there are examples with the compiler. EX_SISR, shows a reasonable handler for the serial interrupt. Add this to basic code for one other interrupt. Get this working _before_ adding another.
Page 2 of 2
