Posted: Thu Feb 19, 2009 7:22 pm |
If this program doesn't work, when typing characters in a serial terminal
window on your PC, then I'd say there is something wrong with your
hardware.
Code: | #include <18F2550.h>
#fuses HS, NOWDT, PUT, NOBROWNOUT, NOLVP
#use delay(clock=20000000)
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
char c;
c = getc(); // Get char from PC
putc(c); // Send it back to the PC
Posted: Sat Feb 21, 2009 7:35 am |
I hope you can help me. I used the echo routine you posted and I am able to echo character keypresses. The problem is that the characters echoed is not character that was pressed (mostly 0XFAs).
This is on a 16F690 using the internal oscillator. The exact code I am using is as follows:
#include <16F690.h>
#fuses HS, NOWDT, PUT, NOBROWNOUT,INTRC_IO
#use rs232(baud=9600, xmit=PIN_C6, parity=N, rcv=PIN_C7, ERRORS)
char c;
setup_oscillator(OSC_4MHZ); /* tried this with and without */
I suspect that this is a clock/timing issue but I am at a loss what to do next.
TIA |
agimat
Solved |
Posted: Sat Feb 21, 2009 1:31 pm |
Replaced
with
#use delay(clock=8000000)
I was using the 16F690's internal clock at 8Mhz.
That fixed it. _________________ http://rlachenal.com |
Ttelmah Guest
Posted: Sat Feb 21, 2009 3:01 pm |
Also, as a 'comment', get rid of the HS fuse at the start of the fuse line.
You can't select both the HS (high speed crystal) oscillator, and the internal RC oscillator. On some chips, selecting multiple setups like this, will stop it working at all, it is just 'luck' that it is working.
obarcia
serial rs232 reading problem (problema resuelto) |
Posted: Thu May 14, 2009 4:06 pm |
Esta es una solución que alguna vez utilice en la serie de PIC 16Fxxx, leyendo los comentarios de todos ustedes compañeros, he llegado hacer funcionar el PIC18F2550, también tuve problema con la RX (el usart y SPI ) están sobre el mismo pin, borrando esa línea de código setup_spi(SPI_SS_DISABLED) funcionó (PCM programmer), gracias a todos ustedes porque también me sirvió la ayuda de todos ustedes.
#device adc=8
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//------------------------- Variables Globales -------------------------\\
char C='f';
//---------------------------INTERRUPCIONES-----------------------------\\
#int_RDA
void serial_isr() { // Interrupción recepción serie USART
C=0x00; // Inicializo caracter recibido
if(kbhit()){ // Si hay algo pendiente de recibir ...
C=getc(); // lo descargo y ...
printf("char: ");
putc(c);
printf("\r\n");
//----------------------PROGRAMA PRINCIPAL-------------------------------\\
enable_interrupts(INT_RDA);
enable_interrupts(global);
// TODO: USER CODE!!
printf("Test: ");
putc(c);
printf("\r\n");
while(true)
Solo lo he simulado para este pic18f2550, pero en la serie 16Fxxx si lo he cargado al pic y ha funcionado
obarcia
MONTECRISTI-MANABI-ECUADOR |
