elmo23! Guest
serial rs232 reading problem |
Posted: Thu Feb 19, 2009 5:47 pm |
Hi to all!
I am programming a pic18f2550, and all works correct by now, except that I can not read any data from the serial. I tried hardware and software rs232, different baud rates, (errors, and no erros), different clock speeds and oscilators... but nothing worked till now.
I paste my last sample code (that keeps printing letters 'a'):
#int_TIMER0
void TIMER0_isr(void)
output_toggle(PIN_A0);
#int_TIMER1
void TIMER1_isr(void)
char c = 'f';
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_31250|OSC_PLL_OFF);
// TODO: USER CODE!!
while(true)
putc(c);
printf(" test\r\n");
while(!kbhit())
putc('a');
c = getc();
printf("char: ");
putc(c);
#include <18F2550.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
I tried getc() with and without kbhit() ,but the result is the same :(
I hope you can help me!!! ;)
(the ccs version is 4.084)
thanks a lot! |
Posted: Thu Feb 19, 2009 5:59 pm |
Quote: | void main()
char c = 'f';
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
Delete the line shown in bold. On this PIC, the UART's Rx signal and the
SPI SDO signal are on the same pin. The line in bold will enable the SPI
module and set the SDO pin as an output. This is the opposite of what
is required for the Rx pin to be operational.
The truth is that all the Wizard lines above can be deleted. They don't
add anything to the program. All those modules are disabled upon
power-on reset anyway. |
elmo23! Guest
Posted: Thu Feb 19, 2009 6:47 pm |
Thanks a lot for the fast answer, unfortunately that didn't work.
I deleted that line and the behaviour is the same. I suppose there must be something else wrong because if I use a soft the same is happening...
#use rs232(baud=57600,parity=N,xmit=PIN_B6,rcv=PIN_B7,bits=8,ERRORS)
All the time letter 'a' is printed and the led in PIN_A0 is blinking (at the right speed). Later I also erased other code generated by the project wizard, without any success.
(I think there are no hardware errors because I connected a gps device I have to the pins of the socket, and it is able to send and receive data, I also use another new pic18f2550, in case this was damaged).
thank you ![Smile](images/smiles/icon_smile.gif) |
Posted: Thu Feb 19, 2009 6:52 pm |
Create a very simple loop that echoes characters back to the PC.
See if that works.
while(true)
c = getc();
putc(c);
elmo23! Guest
Posted: Thu Feb 19, 2009 7:09 pm |
Unfortunately with that simple code (soft and hardware rs232, and different speeds) is not working (sending always worked).
Any new ideas? I will revise everything tomorrow.
thanks a lot for your time. |
Posted: Thu Feb 19, 2009 7:22 pm |
If this program doesn't work, when typing characters in a serial terminal
window on your PC, then I'd say there is something wrong with your
hardware.
Code: | #include <18F2550.h>
#fuses HS, NOWDT, PUT, NOBROWNOUT, NOLVP
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
char c;
c = getc(); // Get char from PC
putc(c); // Send it back to the PC
Posted: Sat Feb 21, 2009 7:35 am |
I hope you can help me. I used the echo routine you posted and I am able to echo character keypresses. The problem is that the characters echoed is not character that was pressed (mostly 0XFAs).
This is on a 16F690 using the internal oscillator. The exact code I am using is as follows:
#include <16F690.h>
#fuses HS, NOWDT, PUT, NOBROWNOUT,INTRC_IO
#use rs232(baud=9600, xmit=PIN_C6, parity=N, rcv=PIN_C7, ERRORS)
char c;
setup_oscillator(OSC_4MHZ); /* tried this with and without */
I suspect that this is a clock/timing issue but I am at a loss what to do next.
TIA |
agimat
Solved |
Posted: Sat Feb 21, 2009 1:31 pm |
Replaced
with
#use delay(clock=8000000)
I was using the 16F690's internal clock at 8Mhz.
That fixed it. _________________ http://rlachenal.com |
Posted: Sat Feb 21, 2009 3:01 pm |
Also, as a 'comment', get rid of the HS fuse at the start of the fuse line.
You can't select both the HS (high speed crystal) oscillator, and the internal RC oscillator. On some chips, selecting multiple setups like this, will stop it working at all, it is just 'luck' that it is working.
obarcia
serial rs232 reading problem (problema resuelto) |
Posted: Thu May 14, 2009 4:06 pm |
Esta es una solución que alguna vez utilice en la serie de PIC 16Fxxx, leyendo los comentarios de todos ustedes compañeros, he llegado hacer funcionar el PIC18F2550, también tuve problema con la RX (el usart y SPI ) están sobre el mismo pin, borrando esa línea de código setup_spi(SPI_SS_DISABLED) funcionó (PCM programmer), gracias a todos ustedes porque también me sirvió la ayuda de todos ustedes.
#device adc=8
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//------------------------- Variables Globales -------------------------\\
char C='f';
//---------------------------INTERRUPCIONES-----------------------------\\
#int_RDA
void serial_isr() { // Interrupción recepción serie USART
C=0x00; // Inicializo caracter recibido
if(kbhit()){ // Si hay algo pendiente de recibir ...
C=getc(); // lo descargo y ...
printf("char: ");
putc(c);
printf("\r\n");
//----------------------PROGRAMA PRINCIPAL-------------------------------\\
enable_interrupts(INT_RDA);
enable_interrupts(global);
printf("Test: ");
putc(c);
printf("\r\n");
while(true)
Solo lo he simulado para este pic18f2550, pero en la serie 16Fxxx si lo he cargado al pic y ha funcionado
obarcia
MONTECRISTI-MANABI-ECUADOR |
