I2C slave transmitting data
Goto page Previous  1, 2, 3, 4  Next
hansimg
PostPosted: Mon May 24, 2010 1:31 pm     Reply with quote
Hey guys, I'm trying to communicate 2 pics 16f877, so I found this topic, and do exactly like you said. But it didn't work. When I try to simulate it in Proteus, the SCL line is kept in 0 and the program does nothing.
Here my master code:
#include <16F877.H>
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
int8 data;
// Write the letter 'B' to the slave board.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
// Read from the slave board and display the data.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1);
data = i2c_read(0);
i2c_stop();
printf("read %c \n\r", data);
And the slave code:
////                         EX_SLAVE.C                                ////
////  This program uses the PIC in I2C slave mode to emulate the       ////
////  24LC01 EEPROM. You can write to addresses 00h to 0Fh with it.    ////
////  This program is to be used in conjunction with the ex_extee.c    ////
////  sample.  Use the "#include <2402.C>" or "#include <2401.c>".     ////
////  Only 16 bytes of address space are implemented, however.         ////
////  If using a compiler version before 2.639 add "*0x14 = 0x3E;" to  ////
////  the begining of main(), and add "NOFORCE_SW" as the last         ////
////  parameter in the #use i2c directive.                             ////
////  Jumpers:                                                         ////
////     PCM,PCH    pin C7 to RS232 RX, pin C6 to RS232 TX             ////
////  This example will work with the PCM and PCH compilers.  The      ////
////  following conditional compilation lines are used to include a    ////
////  valid device for each compiler.  Change the device, clock and    ////
////  RS232 pins for your hardware if needed.                          ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS    ////
//// C compiler.  This source code may only be distributed to other    ////
//// licensed users of the CCS C compiler.  No other use,              ////
//// reproduction or distribution is permitted without written         ////
//// permission.  Derivative programs created using this software      ////
//// in object code form are not restricted in any way.                ////
#if defined(__PCM__)
#include <16F877.h>
#use delay(clock=20000000)
#elif defined(__PCH__)
#include <18F452.h>
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt (){
BYTE incoming, state;
state = i2c_isr_state();
if(state <= 0x80)                     //Master is sending data
    incoming = i2c_read();
    if(state == 1)                    //First received byte is address
        address = incoming;
    if(state == 2)                    //Second received byte is data
        buffer[address] = incoming;
if(state == 0x80)                     //Master is requesting data
    i2c_write(buffer[address]);
void main ()
   enable_interrupts(INT_SSP);
   while (TRUE) {}
Please, help.
Cya
PostPosted: Mon May 24, 2010 1:42 pm     Reply with quote
Put 4.7K pull-up resistors on SCL and SDA.
hansimg
PostPosted: Mon May 24, 2010 1:51 pm     Reply with quote
I already do it. =/
PostPosted: Mon May 24, 2010 2:07 pm     Reply with quote
Post your Proteus schematic on a free image hosting website,
and then post a link to the image in this thread.
hansimg
PostPosted: Mon May 24, 2010 2:17 pm     Reply with quote
PCM_PROGRAMMER thanx for your attention, this is my schematic
PostPosted: Mon May 24, 2010 2:40 pm     Reply with quote
No clock source shown on either chip.
You are specifying 'XT', with a 4MHz delay, which implies an external 4MHz crystal for the master, and HS, and a 20MHz delay, which implies an external 20MHz crystal for the slave. Where are these?.
hansimg
PostPosted: Mon May 24, 2010 3:00 pm     Reply with quote
I Change my schematic to this:
But it's still don't works... =/
X1 -> 4mhz and X2->20mhz
PostPosted: Mon May 24, 2010 3:19 pm     Reply with quote
It could be that Proteus doesn't correctly simulate a software i2c master.
Try adding FORCE_HW to the master:
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
The slave code doesn't need it. The slave always uses hardware i2c.
If that doesn't fix the problem, then it could be caused by your version
of Proteus.
hansimg
PostPosted: Mon May 24, 2010 3:40 pm     Reply with quote
I add force_hw to the master, then the problem was change, now the scl don't go to slow, and the program run until the end, but it's not writing on the slave and neither read.
I receive it on therminal:
"Read -1"
On debug "data" assumes 0xff value
PostPosted: Mon May 24, 2010 3:47 pm     Reply with quote
This thread claims you need Proteus 7.5 SP3. See the last post:
http://support.labcenter.co.uk/forums/viewtopic.php?f=9&t=2275&p=7538&hilit=i2c#p7538
hansimg
PostPosted: Tue May 25, 2010 9:58 am     Reply with quote
Very Happy Very Happy Very Happy Very Happy
I install proteus 7.6 and problem solved.
Thank you so much!!
iVoVa
PostPosted: Thu Mar 17, 2011 10:59 am     Reply with quote
I have a source code about transfer and receive data between MASTER and SLAVE with I2C connect.
Hope it useful for the persons need it.
http://www.mediafire.com/file/l0eq4tuodd5sa1h/I2C%20transfer.rar
Page 3 of 4
