I2C slave transmitting data
Goto page Previous  1, 2, 3, 4  Next
PICdawg
PostPosted: Fri Dec 14, 2007 1:26 pm     Reply with quote
Yes, I forgot that the s/w implementation is only for the master.
Also, I believe the problem in my implementation may be that my read did not specify the NAK parameter. After some review of the i2c spec, pic datasheet and the ccs manual, I think I understand why it should be there and when. I'll try that first!
Is it fair to say that if you are reading multiple data bytes, that your code needs to add the NAK parameter of 0 just to the last read call? I'm assuming this is how the master-receiver signals the slave that the read sequence is finished.
PostPosted: Fri Dec 14, 2007 5:50 pm     Reply with quote
That's correct.
PICdawg
PostPosted: Mon Dec 17, 2007 10:31 am     Reply with quote
Thanks. I did add the NAK parameter to my master-receiver code and my demo program(s) came to life! My slave is running essentially the example slave program. Very simple master program.
I will try to use robotam's prgrams listed on the 1st page of this discussion and see if I can get to work in my proto environment using two 876a's.
robotam
PostPosted: Mon Dec 17, 2007 10:36 am     Reply with quote
Hi PICdawg
can you please explain what did you change in your code?
PICdawg
PostPosted: Mon Dec 17, 2007 7:51 pm     Reply with quote
See my private email to you. Rather than fill up this with the code I answered your question and sent you the code I used for my demo.
robotam
PostPosted: Thu Dec 27, 2007 2:39 am     Reply with quote
I changed my dspic with a 18f as a slave and it works perfectly.i guess there is some modifications or configuration in the dspic.
hansimg
PostPosted: Mon May 24, 2010 1:31 pm     Reply with quote
Hey guys, I'm trying to communicate 2 pics 16f877, so I found this topic, and do exactly like you said. But it didn't work. When I try to simulate it in Proteus, the SCL line is kept in 0 and the program does nothing.
Here my master code:
#include <16F877.H>
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
int8 data;
// Write the letter 'B' to the slave board.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_write('B');
i2c_stop();
// Read from the slave board and display the data.
i2c_start();
i2c_write(0xA0);
i2c_write(0x00);
i2c_start();
i2c_write(0xA1);
data = i2c_read(0);
i2c_stop();
printf("read %c \n\r", data);
And the slave code:
////                         EX_SLAVE.C                                ////
////  This program uses the PIC in I2C slave mode to emulate the       ////
////  24LC01 EEPROM. You can write to addresses 00h to 0Fh with it.    ////
////  This program is to be used in conjunction with the ex_extee.c    ////
////  sample.  Use the "#include <2402.C>" or "#include <2401.c>".     ////
////  Only 16 bytes of address space are implemented, however.         ////
////  If using a compiler version before 2.639 add "*0x14 = 0x3E;" to  ////
////  the begining of main(), and add "NOFORCE_SW" as the last         ////
////  parameter in the #use i2c directive.                             ////
////  Jumpers:                                                         ////
////     PCM,PCH    pin C7 to RS232 RX, pin C6 to RS232 TX             ////
////  This example will work with the PCM and PCH compilers.  The      ////
////  following conditional compilation lines are used to include a    ////
////  valid device for each compiler.  Change the device, clock and    ////
////  RS232 pins for your hardware if needed.                          ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS    ////
//// C compiler.  This source code may only be distributed to other    ////
//// licensed users of the CCS C compiler.  No other use,              ////
//// reproduction or distribution is permitted without written         ////
//// permission.  Derivative programs created using this software      ////
//// in object code form are not restricted in any way.                ////
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F452.h>
#endif
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address, buffer[0x10];
#INT_SSP
void ssp_interupt (){
BYTE incoming, state;
state = i2c_isr_state();
if(state <= 0x80)                     //Master is sending data
    incoming = i2c_read();
    if(state == 1)                    //First received byte is address
        address = incoming;
    if(state == 2)                    //Second received byte is data
        buffer[address] = incoming;
if(state == 0x80)                     //Master is requesting data
    i2c_write(buffer[address]);
void main ()
   enable_interrupts(INT_SSP);
   while (TRUE) {}
Please, help.
Cya
PostPosted: Mon May 24, 2010 1:42 pm     Reply with quote
Put 4.7K pull-up resistors on SCL and SDA.
hansimg
PostPosted: Mon May 24, 2010 1:51 pm     Reply with quote
I already do it. =/
PostPosted: Mon May 24, 2010 2:07 pm     Reply with quote
Post your Proteus schematic on a free image hosting website,
and then post a link to the image in this thread.
hansimg
PostPosted: Mon May 24, 2010 2:17 pm     Reply with quote
PCM_PROGRAMMER thanx for your attention, this is my schematic
PostPosted: Mon May 24, 2010 2:40 pm     Reply with quote
No clock source shown on either chip.
You are specifying 'XT', with a 4MHz delay, which implies an external 4MHz crystal for the master, and HS, and a 20MHz delay, which implies an external 20MHz crystal for the slave. Where are these?.
hansimg
PostPosted: Mon May 24, 2010 3:00 pm     Reply with quote
I Change my schematic to this:
But it's still don't works... =/
X1 -> 4mhz and X2->20mhz
PostPosted: Mon May 24, 2010 3:19 pm     Reply with quote
It could be that Proteus doesn't correctly simulate a software i2c master.
Try adding FORCE_HW to the master:
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
The slave code doesn't need it. The slave always uses hardware i2c.
If that doesn't fix the problem, then it could be caused by your version
of Proteus.
hansimg
PostPosted: Mon May 24, 2010 3:40 pm     Reply with quote
I add force_hw to the master, then the problem was change, now the scl don't go to slow, and the program run until the end, but it's not writing on the slave and neither read.
I receive it on therminal:
"Read -1"
On debug "data" assumes 0xff value
Page 3 of 4
