Having troubles with 16F876A and RS232
PostPosted: Thu Jan 15, 2009 3:23 pm     Reply with quote
Make a very simple test program and see if it works. Type characters
in from Hyperterminal and see if they are sent back properly to the PC.
Example:
#include <16F876A.h>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#int_rda
void rda_isr(void)
char c;
c = getc();  // Get character from PC
putc(c);     // Send it back to the PC
enable_interrupts(INT_RDA);
simons
PostPosted: Thu Jan 15, 2009 3:33 pm     Reply with quote
the example works great! every character is sent back to the pc..
but i can't figure out what's going wrong in my code
PostPosted: Thu Jan 15, 2009 4:05 pm     Reply with quote
Your program is not complete. For example, you don't show the
declaration of iBuff_Rx.
Post the complete program (but about the same length) and post it in
one Code box. Don't split it up over 3 code boxes. Compile it first.
Make it has no errors. Then post it.
Also, add the ERRORS parameter to your #use rs232() statement.
simons
PostPosted: Fri Jan 16, 2009 9:45 am     Reply with quote
Ok here's the complete code, I made a little change but basically it's the same code.
PIN_B4 is check led
PIN_C3 is TX led
PIN_C4 is RX led
all leds are active low.
#device adc=8
#use delay(clock=20000000)
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, ERRORS)
#include "lcd_new.h" //my own lcd driver
BOOLEAN interrupt=0;
char ibuff_Rx;
#int_RDA
RDA_isr()
        ibuff_Rx = getc();
        interrupt=1;
        output_low(PIN_C4); //rx led on
int i;
char check='r';
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   set_tris_a(0b00000000);
   set_tris_b(0b00000000);
   set_tris_c(0b00000000);
   printf(send_char,"\c-WELCOME-");
   printf(send_char,"\c !Work In Progress!\nTest Board by Simons");
   clear_display();
   output_high(PIN_C3);
   output_high(PIN_C4);
   enable_interrupts(global);
   printf("-WELCOME-\n\r");
   output_high(PIN_C4); //all leds off
   if(interrupt==1)
      if(ibuff_Rx=='r')
         output_low(PIN_B4);
         output_low(PIN_C3);
         //31 is a test value
         printf(send_char,"\cRECEIVED: %C \nTEMP: %u",ibuff_Rx,31);
         printf("RECEIVED: %C \rTEMP: %u\r",ibuff_Rx,31);
         ibuff_Rx=' ';
         interrupt=0;
         output_high(PIN_B4);
         output_low(PIN_C3);
         printf(send_char,"\cRECEIVED: %C",ibuff_Rx);
         ibuff_Rx=' ';
         interrupt=0;
      }//if ibuff scope
   }//if interrupt scope
}//while scope
}//main scope
Ok now I notice a thing:
if I remove the printf function that sends out data in rs232, the character is recognised and printed correctly to the lcd.
When I put the printf back, seems like that when the function is called, the interrupt is fired again even if it's a transmission and not a reception.
Thanks for help!
PostPosted: Fri Jan 16, 2009 10:51 am     Reply with quote
Are you sure you have a good ground connection between the systems?. What you describe is exactly what you will see, if the ground is not properly connected, and the system effectively gets grounded through the second data line.
simons
PostPosted: Fri Jan 16, 2009 5:57 pm     Reply with quote
The board where the pic is installed is a demo board, I didn't build it... It has it's own DC Adapter and a rs232 port.
I checked and everything seems fine.. no floating points or non-properly grounded areas..
PostPosted: Fri Jan 16, 2009 6:16 pm     Reply with quote
int i;
char check='r';
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_vref(FALSE);
Get rid of the line in bold. You're setting the Rx pin to be an output.
My advice is to get rid of all the TRIS statements and let the compiler
set the TRIS. It does it automatically when you specify the #use rs232
library. It will do it correctly.
If you get rid of that line I believe it will fix your problem.
simons
PostPosted: Sat Jan 17, 2009 4:44 am     Reply with quote
OMG!! Now it works reeeeally well!!!
Thanks a lot man!!! This is very much appreciated!!! Razz
