[Help] Printf strange behaviour: don't plot zero value
PostPosted: Sat Aug 03, 2013 12:54 am     Reply with quote
I'd suspect the version might be quite early. PCD, had some printf problems in the past with 32bit integers, around the low 4.100's.
It gives the correct answer in 4.107, but is faulty in 4.099.
It will though work correctly, if you specify a field width. Just use:
printf("%1Ld,",temp);
Basically with a zero value, it displays nothing, rather than the zero. Specifying a single character minimum field width forces it to output one character in this situation, and the zero is then displayed.
CoverUp
PostPosted: Wed Aug 07, 2013 9:15 am     Reply with quote
Our version is CCS 4.104
i tried with
The output is
100,50, ,10
100,50, ,10
100,50, ,10
...etc.
So "nothing" is replaced by "space". So you guys are right, it's a PCD bug and we need to update.
