[Help] Printf strange behaviour: don't plot zero value
CoverUp
PostPosted: Fri Aug 02, 2013 9:29 am     Reply with quote
Hi everyone
I got the following issue, i will really appreciate any help of you guys.
System info:
CCS 4.1
MPLAB 8.88
dSPIC 33FJ256GP506 @60Mhz
All the code it's fully functional, but i got an issue with printf.
//...Fuses, clock, use rs232, etc. (all set)
signed int32 temp;
void main(){
//..init dspic, port,etc. (all set)
  while(1){
     temp=100;
     printf("%Ld,",temp);
     temp=50;
     temp=0;
     temp=10;
     printf("%Ld\r,",temp);
  }//end while
} //end main
Expected output:
100,50,0,10
100,50,0,10
100,50,0,10
...etc.
The output that i get
100,50,,10
100,50,,10
100,50,,10
...etc.
So the problem is: I can't plot a zero value
temp must be signed int32, because it will be updated in a function, with the real value (this function is disabled for now)
I simplify the code to show my point that printf don't plot zero values
Any help will be appreciated
NOTE: All others variable types work fine, this issue is only with signed int32 variable type.
ie:
printf("%4.0f,",(float) temp);
Works fine, and is a workaround to this. but i want to understand why this fail using signed int32.
PostPosted: Fri Aug 02, 2013 4:45 pm     Reply with quote
temp=0;
No one else has replied so I'll help somewhat. I don't have the PCD
compiler. So I tested your code with an 18F4620 with versions 4.141
and 5.010 in MPLAB simulator and it works OK. So it may be a bug with
PCD with your version.
CCS 4.1
Also, this is not a version. Versions have four digits.
PostPosted: Sat Aug 03, 2013 12:54 am     Reply with quote
I'd suspect the version might be quite early. PCD, had some printf problems in the past with 32bit integers, around the low 4.100's.
It gives the correct answer in 4.107, but is faulty in 4.099.
It will though work correctly, if you specify a field width. Just use:
printf("%1Ld,",temp);
Basically with a zero value, it displays nothing, rather than the zero. Specifying a single character minimum field width forces it to output one character in this situation, and the zero is then displayed.
CoverUp
PostPosted: Wed Aug 07, 2013 9:15 am     Reply with quote
Our version is CCS 4.104
i tried with
The output is
100,50, ,10
100,50, ,10
100,50, ,10
...etc.
So "nothing" is replaced by "space". So you guys are right, it's a PCD bug and we need to update.
