PIC16F84A error.
gonzalza
PostPosted: Thu Feb 25, 2010 2:57 pm     Reply with quote
I'm trying this simple code but when I compile I'm having this problem:
Error [141] C:\Users\maiky\Documents\Glyndwr\PIC\sara\84conc.c; 3.19 can't open include file "16f84A.h": No such file or directory
Where can I find the include files?
PostPosted: Thu Feb 25, 2010 3:15 pm     Reply with quote
Error [141] No such file or directory
That message comes from the Hi-Tech C compiler. This forum is for
the CCS compiler. You need to ask your questions on the Hi-Tech forum:
http://forum.htsoft.com/all/ubbthreads.php
Also, Microchip has a Hi-Tech compiler forum:
http://www.microchip.com/forums/tt.aspx?forumid=231
Finally, that code is for the CCS compiler. You need to use code that
is designed for the Hi-Tech compiler. The two compilers are not
compatible. All code on this forum is for CCS and will not compile
with the Hi-Tech compiler.
gonzalza
PostPosted: Thu Feb 25, 2010 4:36 pm     Reply with quote
i see, i was using ccs compiler and i changed because it was asking me reinstalltion when it was installed, thanks
