PIC16F84A error.
dane
PIC16F84A error.
PostPosted: Wed Dec 09, 2009 5:53 am     Reply with quote
Hi, this is my program
#include <16F84A.h>
#fuses NOWDT                    //No Watch Dog Timer
#fuses NOPROTECT                //Code not protected from reading
#fuses NOLVP
#fuses NOBROWNOUT               //No brownout reset
#fuses NOPUT
#fuses INTRC
#use delay (clock=4000000)   //Crystal at 20Mhz
   unsigned char i,j,k;
      if(input(PIN_B0) && input(PIN_B1))
         for(i=0;i<25;i++)
                for(j=0;j<255;j++)
                        for(k=0;k<255;k++)
                     output_a(0x01);
         for(i=0;i<25;i++)
                for(j=0;j<255;j++)
                        for(k=0;k<255;k++)
                     output_a(0x02);
and CCS compiler has 3 errors which says:
Unknown keyword in statement NOLVP
NOBROWNOUT, and INTRC
What must I do? Thanks
anandpv2009
PostPosted: Wed Dec 09, 2009 7:02 am     Reply with quote
Remove the following code from your program.
#fuses NOLVP
#fuses INTRC
gonzalza
PostPosted: Thu Feb 25, 2010 2:57 pm     Reply with quote
I'm trying this simple code but when I compile I'm having this problem:
Error [141] C:\Users\maiky\Documents\Glyndwr\PIC\sara\84conc.c; 3.19 can't open include file "16f84A.h": No such file or directory
Where can I find the include files?
PostPosted: Thu Feb 25, 2010 3:15 pm     Reply with quote
Error [141] No such file or directory
That message comes from the Hi-Tech C compiler. This forum is for
the CCS compiler. You need to ask your questions on the Hi-Tech forum:
http://forum.htsoft.com/all/ubbthreads.php
Also, Microchip has a Hi-Tech compiler forum:
http://www.microchip.com/forums/tt.aspx?forumid=231
Finally, that code is for the CCS compiler. You need to use code that
is designed for the Hi-Tech compiler. The two compilers are not
compatible. All code on this forum is for CCS and will not compile
with the Hi-Tech compiler.
gonzalza
PostPosted: Thu Feb 25, 2010 4:36 pm     Reply with quote
i see, i was using ccs compiler and i changed because it was asking me reinstalltion when it was installed, thanks
