During the initialization process, sometimes, for a very short period of time, I was pulling the chip TX line low while the chip was trying to pull it up for sending data. This effectively created a short circuit.
I changed the code and so far it works fine.
Posted: Mon Jan 08, 2024 10:11 am
You do realise there is a standard driver for the DS1302 with the compiler?.
pastruga
Posted: Fri Jan 12, 2024 8:48 pm
Yes, but the root cause was a wrong set of numbers. I used the RX line as TX. The driver works, but the initialization process (the PINS declaration) wasn't done properly.
Page 2 of 2
