DS1302 high current problem
Goto page Previous  1, 2
pastruga
PostPosted: Sun Jan 07, 2024 7:46 pm     Reply with quote
I think you are right.
During the initialization process, sometimes, for a very short period of time, I was pulling the chip TX line low while the chip was trying to pull it up for sending data. This effectively created a short circuit.
I changed the code and so far it works fine.
PostPosted: Mon Jan 08, 2024 10:11 am     Reply with quote
You do realise there is a standard driver for the DS1302 with the compiler?.
pastruga
PostPosted: Fri Jan 12, 2024 8:48 pm     Reply with quote
Yes, but the root cause was a wrong set of numbers. I used the RX line as TX. The driver works, but the initialization process (the PINS declaration) wasn't done properly.
Page 2 of 2
