problem with store the int32 variable in memory...
PostPosted: Wed Mar 18, 2009 11:52 pm     Reply with quote
Look at this CCS FAQ article:
http://www.ccsinfo.com/faq.php?page=write_eeprom_not_byte
Also, read some other forum posts, because a similar topic
was answered only a few hours ago.
In the write routine (in the link above) make these changes:
Change 'WRITE_FLOAT_EXT_EEPROM' to 'Write_int32_eeprom'
Change 'float data' to 'int32 data'
Change 'write_ext_eeprom' to 'write_eeprom'
In the read routine (in the link above) make these changes:
Change 'float READ_FLOAT_EXT_EEPROM' to 'int32 read_int32_eeprom'
Change 'read_ext_eeprom' to 'read_eeprom'
The eeprom address must be increased by 4 bytes, each time you
write a new int32 value.
karthickiw
thank you...
PostPosted: Thu Mar 19, 2009 7:29 am     Reply with quote
thank you... its work Laughing
