CAN problem - getting started
Goto page Previous  1, 2
PostPosted: Fri Jul 29, 2005 4:42 pm     Reply with quote
Uh, the mystery deepens. I'm still using the 18LF458's, not the 4580's. ???
Nope, just found it: they did the same thing in the can-18xxx8.h file. I changed that line to define CAN_ENABLE_DRIVE_HIGH to 1. Now everything works without the external pullups.
PCM, again, thanks. I owe you many beers.
PostPosted: Fri Jul 29, 2005 5:00 pm     Reply with quote
Oops.
The 18F458 does have that bit. I didn't see it on a quick look at the
data sheet. Also, the can-18xxx8 driver sets ENDRHI = 0 as well.
So how does it work on my boards ? I'll have to investigate this further.
OK. Mystery solved. The CAN bus transceiver chips that I've used
in the past have got an internal pull-up on the TX pin.
From page 5 of the MCP2551 data sheet:
TXD has an internal pull-up resistor (nominal 25 k)
The LT1796 transceivers don't have an internal pull-up. The data
sheet doesn't show it. That finally explains everything.
hoanf
PostPosted: Fri Sep 21, 2007 10:00 pm     Reply with quote
Thank for your code!
But now how we can use the filter to get the message by using CAN driver . Please give the guide
Cheers
Tran Hoan
PostPosted: Fri Sep 21, 2007 11:23 pm     Reply with quote
Use the forum's search page. The information is in the forum archives.
http://www.ccsinfo.com/forum/search.php
Search for the function name that's used to setup the Rx filters.
The function name is: can_set_id
Search for that.
Also search for: can bus filter
Set it to: Seach for all terms
There are several threads on it. Here are a few hits.
http://www.ccsinfo.com/forum/viewtopic.php?t=29533
http://www.ccsinfo.com/forum/viewtopic.php?t=27325
http://www.ccsinfo.com/forum/viewtopic.php?t=24198
dan taulbee
CAN troubles
PostPosted: Wed Mar 26, 2008 11:43 am     Reply with quote
My situation is this:
I'm using a PIC18F4680, and I'm running ex_can.c with the 18xxx8.c and .h files. I do NOT have a CAN developer kit with an LCD display, so I'm pretty sure the printf statements are useless for me. I'm using a program called PCAN-View that monitors the CAN bus. Shouldn't I be receiving the messages from the CANH and CANL pins? The software works when hooked up to a vehicle's CAN bus, but isn't picking anything up from the CAN-EX file.
Dan
dan taulbee
resolved
PostPosted: Thu Mar 27, 2008 7:24 am     Reply with quote
Ok, now I'm getting CAN data on the CANH and CANL pins of my board. I am not, however, receiving this data on my computer's software. The software (and adapter) once again is PCAN-USB.
PostPosted: Thu Mar 27, 2008 11:04 am     Reply with quote
What board do you have ?
Page 2 of 2
