newguy
Posted: Fri Jul 29, 2005 4:42 pm |
Uh, the mystery deepens. I'm still using the 18LF458's, not the 4580's. ???
Nope, just found it: they did the same thing in the can-18xxx8.h file. I changed that line to define CAN_ENABLE_DRIVE_HIGH to 1. Now everything works without the external pullups.
PCM, again, thanks. I owe you many beers. |
Posted: Fri Jul 29, 2005 5:00 pm |
Oops.
The 18F458 does have that bit. I didn't see it on a quick look at the
data sheet. Also, the can-18xxx8 driver sets ENDRHI = 0 as well.
So how does it work on my boards ? I'll have to investigate this further.
OK. Mystery solved. The CAN bus transceiver chips that I've used
in the past have got an internal pull-up on the TX pin.
From page 5 of the MCP2551 data sheet:
Quote: | TXD has an internal pull-up resistor (nominal 25 k) |
The LT1796 transceivers don't have an internal pull-up. The data
sheet doesn't show it. That finally explains everything. |
hoanf
Posted: Fri Sep 21, 2007 10:00 pm |
Thank for your code!
But now how we can use the filter to get the message by using CAN driver . Please give the guide
Cheers
Tran Hoan |
dan taulbee Guest
CAN troubles |
Posted: Wed Mar 26, 2008 11:43 am |
My situation is this:
I'm using a PIC18F4680, and I'm running ex_can.c with the 18xxx8.c and .h files. I do NOT have a CAN developer kit with an LCD display, so I'm pretty sure the printf statements are useless for me. I'm using a program called PCAN-View that monitors the CAN bus. Shouldn't I be receiving the messages from the CANH and CANL pins? The software works when hooked up to a vehicle's CAN bus, but isn't picking anything up from the CAN-EX file.
Dan |
dan taulbee Guest
resolved |
Posted: Thu Mar 27, 2008 7:24 am |
Ok, now I'm getting CAN data on the CANH and CANL pins of my board. I am not, however, receiving this data on my computer's software. The software (and adapter) once again is PCAN-USB. |
Posted: Thu Mar 27, 2008 11:04 am |
Quote: | I do NOT have a CAN developer kit |
What board do you have ? |
