daveh Guest
C++ code examples for USB bulk transfer? |
Posted: Wed Jun 04, 2008 12:13 pm |
Hi, does anyone have any suggestions of sites with c++ code examples for interfacing with a USB device (pref PIC18F4550)? Ideally what I'd like is something like CCS' OScope source code in C++.
I did find some C++ code on Microchip's site but I couldn't compile it since I'm using Visual C++ 2008 Express Edition which doesn't have the MFC library. Maybe I'll have to buy the full version.
The reason I want to use C++ is that we already have a program written in C++ that I'd like to incorporate an interface to access the PIC18F4550 into.
Also, if I search the forum for c++ or "c++" it doesn't return anything. Any suggestions for how to search for that?
Any advice would be appreciated. |
Indy
Re: C++ code examples for USB bulk tranfer? |
Posted: Wed Jun 04, 2008 3:14 pm |
daveh wrote: | Also, if I search the forum for c++ or "c++" it doesn't return anything. Any suggestions for how to search for that? | Use Google with the search string: c++ site:http://www.ccsinfo.com/forum
Sorry, I can't help you on the C++ / USB questions. |
daveh Guest
Posted: Fri Jul 11, 2008 12:17 pm |
I'll post my demo code below in case it will help anyone in the future. The code was complied with VC++ 2008 Express Edition. It connects to the Microchip PICDEM FS USB board with the "USB Device - MCHPUSB - Generic Driver - C18 - PICDEM FSUSB.hex" firmware installed.
This code requests and displays the Firmware version number, the Pot value and the temp sensor (U4) value.
Code: | // June18.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "windows.h"
#include <iostream>
using std::cout;
using std::cin;
using std::endl;
#include "mpusbapi.h"
// Global Vars
HINSTANCE libHandle;
HANDLE myOutPipe;
HANDLE myInPipe;
DWORD current_instance=0;
DWORD temp;
double pot_val;
double temp_val;
char vid_pid[]= "vid_04d8&pid_000c"; // MCHPUSB - Generic Driver vid_pid
char out_pipe[]= "\\MCHP_EP1";
char in_pipe[]= \\MCHP_EP1;
typedef enum
READ_VERSION = 0x00,
READ_FLASH = 0x01,
WRITE_FLASH = 0x02,
ERASE_FLASH = 0x03,
READ_EEDATA = 0x04,
WRITE_EEDATA = 0x05,
READ_CONFIG = 0x06,
WRITE_CONFIG = 0x07,
ID_BOARD = 0x31,
UPDATE_LED = 0x32,
SET_TEMP_REAL = 0x33,
RD_TEMP = 0x34,
SET_TEMP_LOGGING= 0x35,
RD_TEMP_LOGGING = 0x36,
RD_POT = 0x37,
RESET = 0xFF
}TYPE_CMD;
// Protoypes ----------------------------------------------------------------
void LoadMPUSBDLL();
void GetSummary();
void SetInstance();
void ReadHWVer();
void ReadPotVal();
void ReadTempVal();
DWORD SendReceivePacket(BYTE *SendData, DWORD SendLength, BYTE *ReceiveData, DWORD *ReceiveLength, UINT SendDelay, UINT ReceiveDelay);
void CheckInvalidHandle();
int _tmain(int argc, _TCHAR* argv[])
BOOLEAN bQuit = false;
CHAR selection;
printf("PICDEM FS USB Connection Demo \n\r");
printf("------------------------------\n\r");
LoadMPUSBDLL(); // load DLL
ReadPotVal(); // read Pot Value
ReadTempVal(); // read Temp Value
myOutPipe = myInPipe = INVALID_HANDLE_VALUE;
printf("The VID/PID being tested => %s \n\r",vid_pid);
temp = MPUSBGetDLLVersion();
printf("DLL Version => %X.%04X \n\r",HIWORD(temp),LOWORD(temp));
printf("Device Count => %d \n\n\r",MPUSBGetDeviceCount(vid_pid));
while(!bQuit)
printf("Select an option\n\r");
printf("[1] Summarize Instances\n\r");
printf("[2] Get USB Demo Firmware Version\n\r");
printf("[3] Read Pot Value: %0.1f%%\n\r",pot_val);
printf("[4] Read Temp Value: %0.1f%cC\n\r",temp_val,0xF8);
printf("[9] Set new Instance: %d\n\r",current_instance);
printf("[Q] Quit\n\r>>");
cin >> selection;
switch(selection)
case '1':
GetSummary();
case '2':
ReadHWVer();
case '3':
ReadPotVal();
case '4':
ReadTempVal();
case '9':
SetInstance();
case 'Q':
bQuit = true;
case 'q':
bQuit = true;
}// end of switch
fflush(stdin);
printf("\n\r");
}// end of while
if (myOutPipe != INVALID_HANDLE_VALUE) MPUSBClose(myOutPipe);
if (myInPipe != INVALID_HANDLE_VALUE) MPUSBClose(myInPipe);
if (libHandle != NULL) FreeLibrary(libHandle);
return 0;
void LoadMPUSBDLL()
libHandle = NULL;
libHandle = LoadLibrary(_T("mpusbapi"));
if(libHandle == NULL)
printf("LoadLibrary => ERROR \n\r");
printf("LoadLibrary => Success \n\r");
MPUSBGetDLLVersion=(DWORD(*)(void))\
GetProcAddress(libHandle,"_MPUSBGetDLLVersion");
MPUSBGetDeviceCount=(DWORD(*)(PCHAR))\
GetProcAddress(libHandle,"_MPUSBGetDeviceCount");
MPUSBOpen=(HANDLE(*)(DWORD,PCHAR,PCHAR,DWORD,DWORD))\
GetProcAddress(libHandle,"_MPUSBOpen");
MPUSBWrite=(DWORD(*)(HANDLE,PVOID,DWORD,PDWORD,DWORD))\
GetProcAddress(libHandle,"_MPUSBWrite");
MPUSBRead=(DWORD(*)(HANDLE,PVOID,DWORD,PDWORD,DWORD))\
GetProcAddress(libHandle,"_MPUSBRead");
MPUSBReadInt=(DWORD(*)(HANDLE,PVOID,DWORD,PDWORD,DWORD))\
GetProcAddress(libHandle,"_MPUSBReadInt");
MPUSBClose=(BOOL(*)(HANDLE))GetProcAddress(libHandle,"_MPUSBClose");
if((MPUSBGetDeviceCount == NULL) || (MPUSBOpen == NULL) ||
(MPUSBWrite == NULL) || (MPUSBRead == NULL) ||
(MPUSBClose == NULL) || (MPUSBGetDLLVersion == NULL) ||
(MPUSBReadInt == NULL))
printf("GetProcAddress => Error\r\n");
else printf("GetProcAddress => Success \n\r");
}//end if else
}//end LoadDLL
void GetSummary()
HANDLE tempPipe = INVALID_HANDLE_VALUE;
DWORD count=0;
DWORD max_count = MPUSBGetDeviceCount(vid_pid);
printf("\n\r%d device(s) with %s currently attached\n\r",max_count,vid_pid);
for(int i=0; i< MAX_NUM_MPUSB_DEV; i++)
tempPipe = MPUSBOpen(i,vid_pid,NULL,MP_READ,0);
if(tempPipe != INVALID_HANDLE_VALUE)
printf("Instance Index # %d\n\r",i);
MPUSBClose(tempPipe);
count++;
if(count == max_count) break;
}//end of for
printf("\n\r");
}//end of GetSummary
void SetInstance()
DWORD selection;
fflush(stdin);
printf("Enter a valid instance index to open a USB connection: ");
cin >> selection;
myOutPipe = MPUSBOpen(selection,vid_pid,out_pipe,MP_WRITE,0);
myInPipe = MPUSBOpen(selection,vid_pid,in_pipe,MP_READ,0);
if(myOutPipe == INVALID_HANDLE_VALUE || myInPipe == INVALID_HANDLE_VALUE)
printf("Failed to open data pipes.\n\r");
return;
else current_instance = selection;
void ReadHWVer()
myOutPipe = MPUSBOpen(current_instance,vid_pid,out_pipe,MP_WRITE,0);
myInPipe = MPUSBOpen(current_instance,vid_pid,in_pipe,MP_READ,0);
return;
BYTE send_buf[64],receive_buf[64];
DWORD RecvLength=4;
send_buf[0] = READ_VERSION; // command
send_buf[1] = 0x02; // expected length of return value
if(SendReceivePacket(send_buf,2,receive_buf,&RecvLength,1000,1000) ==1)
if(RecvLength==4 && receive_buf[0] == READ_VERSION && receive_buf[1] == 0x02)
printf("\nPICDEM FS Firmware Ver %d.%d\n\r",receive_buf[3],receive_buf[2]);
else printf("USB Operation Failed\n\r");
}//end ReadHWVer()
void ReadPotVal()
return;
DWORD RecvLength=3;
send_buf[0] = RD_POT; // command
if(RecvLength==3 && receive_buf[0] == RD_POT)
pot_val = (receive_buf[2]*256+receive_buf[1])/10.2; // max reading is 1020
}//end ReadPotVal()
void ReadTempVal()
return;
DWORD RecvLength=3;
send_buf[0] = RD_TEMP; // command
if(RecvLength==3 && receive_buf[0] == RD_TEMP)
temp_val = (receive_buf[2]*256+receive_buf[1])/8*0.0625; // strip 3 lowest bits - 1 LSB = 0.0625 degC
}//end ReadTempVal()
DWORD SentDataLength;
DWORD ExpectedReceiveLength = *ReceiveLength;
if(myOutPipe != INVALID_HANDLE_VALUE && myInPipe != INVALID_HANDLE_VALUE)
if(MPUSBWrite(myOutPipe,SendData,SendLength,&SentDataLength,SendDelay))
if(MPUSBRead(myInPipe,ReceiveData,ExpectedReceiveLength,ReceiveLength,ReceiveDelay))
if(*ReceiveLength == ExpectedReceiveLength)
return 1; // success
else if(*ReceiveLength < ExpectedReceiveLength)
return 2; // Partially failed, wrong length
else CheckInvalidHandle();
}// end if
return 0; // Operation Failed
}// end SendReceivePacket()
if(GetLastError() == ERROR_INVALID_HANDLE)
printf("Error Code %d\n\r",GetLastError());
