multidimensional array to functions arg
xxx
PostPosted: Mon Jun 02, 2008 6:00 am     Reply with quote
Hello
I have a problem.
I would like to pass a constant multidimensional array to a function but having trouble reading the array elements when passed. the code is:
// multi array to pass as arg to function
char MANUAL_bitmap[5][9] ={     {0b00000000,0b00000000,0b00011000,0b00011010,0b00011010,0b00011010,0b00011010,0b00011010,0b00000000},     /* 0x44*/
{0b00000000,0b00111111,0b01101101,0b01101101,0b01101101,0b01101101,0b01101101,0b01101101,0b00000000}, /* 0x43*/
{0b00000000,0b00000000,0b10000000,0b10011110,0b10110110,0b10110110,0b10110110,0b10011110,0b00000000},     /* 0x42*/ {0b00000000,0b00000000, 0b00000000,0b01110011,0b11011011,0b11011011,0b11011011,0b11011001,0b00000000},  /* 0x41*/
{0b00000000,0b00000000, 0b00000000,0b01100111,0b01101101, 0b01101101,0b01101101,0b11000111,0b00000000},   /* 0x40*/
// function to use multi array
void displayOptions_178(char Invert, char ptr[5][9]){
char yMarker = 0, xMarker = 0;
char tmepUi8 = 0;
/* clear title section manul auto part */
clearSection_178();
for(xMarker = 0; xMarker<5;xMarker++)
     wr_cmd(0x20);
     wr_cmd(0x44-xMarker);        // x address
     for(yMarker=0;yMarker<9;yMarker++)
         wr_cmd(178+yMarker);          // y address
         if(Invert == HIGHLIGHT_AUTO ) // highight manual
         // tmepUi8   = *(*(ptr + yMarker) + xMarker);
         // tmepUi8 = ptr[xMarker][yMarker];
            wr_data((char)~(ptr[xMarker][yMarker])); // yes invert
            wr_data((ptr[xMarker][yMarker]));       // no invert
The wr_cmd and wr_data are for sending commands to a lcd driver and wr_data is a method to send the actual data.
The array that I try to send is a piece of a bitmap which i would like to display. However having trouble reading elements.
Can anyone help. I know there are alternatives, but need multidimensional array to work.
thanks
PostPosted: Mon Jun 02, 2008 12:09 pm     Reply with quote
1. Post a little test program that shows how you are calling that function.
Show all variable declarations.
2. Post your PIC.
3. Post your compiler version.
XXX
PostPosted: Tue Jun 03, 2008 2:40 am     Reply with quote
Hi PCM Programmer
The compiler version is 4.062
PIC is a PIC18F8520
#include<18F8520.h>
#FUSES H4
#device adc=10
#device  high_ints = true;
#use delay(clock=40000000)
#use rs232(baud = 115000,xmit=PIN_C6,rcv=PIN_c7)
const char MANUAL_bitmap[5][9] ={     {0b00000000,0b00000000,0b00011000,0b00011010,0b00011010,0b00011010,0b00011010,0b00011010,0b00000000},     /* 0x44*/
void displayOptions_178(char ptr[5][9]){
                  printf("%d\n\r" ptr[xMarker][yMarker]); // yes invert
void main(){
    displayOptions_178(MANUAL_bitmap);
I have modified the code so that it is a simple function that takes a mutidimensional array and prints the elements out to screen. However it does not work. Tried other ways but still doesnt work, probably its my understanding so any tips would be good. Please note that I would like to use const array if possible.
thanks
PostPosted: Tue Jun 03, 2008 3:34 am     Reply with quote
For testing, get rid of 'high_ints=true'. This _must not_ be enabled, if you do not have a high priority interrupt handler enabled, but do have other interrupt handlers present. Because of the way the hardware works on the chip, if interrupt priorities are enabled (which this does), some interrupts _must_ be high priority. If you enable this, and don't have any high priority interrupts actually enabled, it can cause major problems...
Second, add the 'NOXINST' fuse. Though this should be the default, make sure...
The big one though, is to use the 'ROM' declaration, rather than the 'const' declaration. As it currently stands, you are passing the pointer in the call (which is not legal for a constant array, unless you have '#device CONST=ROM' selected, or use the ROM declaration), but the receiving routine, expects to get the pointer to the array...
