rklan Guest
problem with UART on 16f688 |
Posted: Sat May 31, 2008 3:00 am |
I like to use the hardware uart in my 16f688.
It doesn't work yet.
When I use software uart it works fine. But i like to use interrupt so I have to use hardware uart.
I tried this:
while (TRUE)
#use rs232(baud=9600,bits=8,xmit=PIN_C1,rcv=PIN_C2,ERRORS) //use hardware uart
c=getchar();
putchar('@');
putchar(c);
This works with C1 and C2.... but when I use C4 and C5 (this must be the hardware UART, it does not receive......
Can anyone help?? |
Posted: Sat May 31, 2008 4:26 am |
First, put the #USE_RS232 directive outside the program (or certainly outside the _while_ loop). This is a _preprocessor_ directive, setting up the port. It does cause the addition of configuration code for the UART, and if placed outside the code, this is automatically put at the start of the program. Including it inside the while loop, could result in this code being included in the loop, and this might well cause problems with the hardware UART....
Second, add the line to disable the comparator module in front of this code. The RC4 pin, is multiplexed with the comparator 2 output, and this could also cause problems (setup_comparator(NC_NC_NC_NC);).
Then, if it still doesn't work, post the compiler version. There was a fault on some versions of the compiler, not correctly initialising some peripherals like the comparator, and we will probably know if yours was a version with this problem.
rklan Guest
Posted: Sat May 31, 2008 5:23 am |
Thanks!!
But it doesn't work yet....
I placed the #use rs232 directive in the loop, because I like to use a 2nd uart, later..
I like to receive from one and transfer to another.
But, the setup comparator(nc_nc_nc_nc) didn't help...
My compiler version:3.203
Thanks for your help! |
Posted: Sat May 31, 2008 8:22 am |
You still don't want to put the #use directive inside the loop. Do a search here on how to use two setups. They don't work as if they are a normal part of the code. The last one 'passed' in _linear_ routing (ignoring any loops), will be the one that applies. Really, it'd be very much easier to use streams, and these were introduced before your compiler version (about 3.180), so are the way to go. Look in the 'readme.txt' for your compiler which describes these.
Ouch. 3.203, is old. I'd be very suspicious this is not working right. Though I have older compilers, I have nothing comparable in the early 3.2xx versions, since I threw these away, as 'non usable', till about 3.221...
Do a search here, PCM programmer, has posted manual initialisation routines, for some of the early compiler problems in the past, that should get the basic serial working.
Humberto
Posted: Sat May 31, 2008 8:42 am |
Quote: | This works with C1 and C2.... but when I use C4 and C5 (this must be the hardware UART, it does not receive...... |
#use rs232 is a pre-processor directive used at compilation time to configure the MCU,
hence -as Ttelmah said- it should be at the beginning.
To receive a char using the hardware UART you need:
1) enable the INT_RDA
2) enable the INT_GLOBAL
3) put the code inside the interrupt service routine.
PCM Version 3.203 was released in Jul/2004. I suggest you not to use it for a comercial product.
Humberto |
rklan Guest
Posted: Sat May 31, 2008 9:32 am |
It still does not work with the hardware uart...
I'll get a new compiler first.... that would be a nice idea....
Thanks for the tips everyone!
Code: | #include <16f688.h>
#fuses INTRC,NOWDT,NOPROTECT, NOMCLR
#use delay(clock=8000000)
#use rs232(baud=9600,bits=8,xmit=PIN_C4,rcv=PIN_C5,ERRORS) //use hardware uart
char c;
#int_rda
void Rx_isr() {
printf("/r/ntest");
enable_interrupts(global);
enable_interrupts(int_rda);
while (TRUE)
delay_ms (200); //wait
putchar('@');
Humberto
Posted: Sat May 31, 2008 1:00 pm |
Try this:
#include <16f688.h>
#fuses PUT,INTRC,NOWDT,NOPROTECT, NOMCLR
char c;
#int_rda
void Rx_isr() {
c=getchar();
putchar(c);
setup_oscillator(OSC_8MHZ);
printf("/r/nTest");
while (TRUE)
output_low(PIN_Bx); // Connect a LED in Bx to "see" that it is doing something
delay_ms(200);
output_high(PIN_Bx);
delay_ms(200);
Humberto |
rklan Guest
16f688 UART Problem |
Posted: Mon Jun 02, 2008 11:40 am |
Hi Folks,
I bought myself a new compiler today.... and it's working!
So the bug was in my, very old, compiler.
Thanks for al the good code and tips.!! |
