mutevaggil
missing pulses in counting |
Posted: Thu May 29, 2008 9:32 am |
hi, i am programming a pulse counter. there is a proximity sensor... my program takes its movement as pulses. it works. but if speed rise, it is happening some missing pulses, rarely but exist.
how can I do not to miss pulse and counts exactly.
by the way, i use capture compare module |
RLScott
Re: missing pulses in counting |
Posted: Thu May 29, 2008 9:39 am |
mutevaggil wrote: | hi, i am programming a pulse counter. there is a proximity sensor... my program takes its movement as pulses. it works. but if speed rise, it is happening some missing pulses, rarely but exist.
You must decide how close together the pulses can be, and then determine how frequently your program is checking for the pulses. If you are counting pulses in your CCP interrupt service routine, and if that
routine takes too much time, then you might easily miss some pulses.
Just because you are using a C compiler, that does not relieve you of the responsibility of checking for time-critical code. It is useful to examine the disassembly listing and count instructions to see how long things take. Or, your could toggle unused outputs at certain places in your code and then measure the timing of those outputs with a 'scope.
Robert Scott
Real-Time Specialties |
