Loop problem
Voltagerange
Loop problem
PostPosted: Thu May 29, 2008 2:34 am     Reply with quote
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//setup_oscillator(OSC_8MHZ|OSC_TIMER1);
disable_interrupts (global);
fputs("Test", SOFT_UART);
fputs("Bla", SOFT_UART);
Anyone knows why this little piece of code shows me this?
Test
Bla
Test
Bla
etc etc.
It looks like my program hangs in a non defined loop.
I hope you guys can help me out.
Thanks alot
andrewg
PostPosted: Thu May 29, 2008 3:48 am     Reply with quote
You don't give your PIC or your fuses, so I'll assume you've got a part where if the WDT is enabled via fuses, it cannot be disabled via software (setup_wdt).
Your code drop off the end, the pic goes to sleep, and the wdt restarts the pic a short while later.
Andrew
Voltagerange
Now everthing is here:)
PostPosted: Thu May 29, 2008 4:19 am     Reply with quote
#include <18F4320.h>
#device adc=8
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#use delay(clock=8000000)
#use rs232(baud=4800,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, stream=HW_UART)
#use rs232(baud=9600,parity=N,xmit=PIN_D0,rcv=PIN_D1,bits=8, stream=SOFT_UART)
Also my whole header file.
RLScott
Re: Now everthing is here:)
PostPosted: Thu May 29, 2008 8:20 am     Reply with quote
I'm not sure why your program is looping, especially since you have the NOWDT fuse specified. But why are you allowing your program to fall off the end? This calls for some experiments. To see if something is resetting your PIC, change the program to:
k = 0;
   k++;
  fprintf(SOFT_UART,"%1d ",k);
What this program does should tell you a lot.
Robert Scott
Real-Time Specialties
Wayne_
PostPosted: Fri May 30, 2008 1:34 am     Reply with quote
Look at the .lst file and see what the last instruction is after the last line in main.
D-Kens
PostPosted: Mon Jun 02, 2008 12:53 am     Reply with quote
I'd suggest that you read the restart_cause() value to check the reason why your PIC is rebooting. Wink
andrewg
PostPosted: Tue Jun 03, 2008 9:19 am     Reply with quote
You do have a pullup on MCLR?
Andrew
RLScott
PostPosted: Tue Jun 03, 2008 10:27 am     Reply with quote
Apparently the OP (Voltagerange) has lost interest in his question. He has not answered any of the helpful questions or suggestions that have been posed for the last 5 days.
Robert Scott
