pic-e
| Highest PWM is only 2.5 Mhz |
Posted: Thu May 29, 2008 7:12 am |
I have a 16F877 running at 20Mhz. Using the formula below, I would think that I should be able to get out a freq of 5 Mhz but it is only 2.5.
| Code: | Crystal Frequency
PWM Freq = -----------------------------------------
(PR2 + 1) * (Timer2 Prescaler) * 4
My code:
#include <16F877.H>
#fuses HS, NOWDT, NOPROTECT, PUT, NOLVP
main()
output_low(PIN_C2); // Set CCP1 output low setup_ccp1 (CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1, 1, 1);
set_pwm1_duty(1); // 50% duty cycle
while(1); // Prevent PIC from going to sleep
RLScott
| Re: Highest PWM is only 2.5 Mhz |
Posted: Thu May 29, 2008 8:09 am |
The period of Timer 2 is (PR2+1) * Prescaler * 4 * Tosc. In your case Tosc = 50 nsec. With PR2=1, this works out to 2*1*4*50 nsec = 400 nsec. Therefore the frequency is 1/400 nsec = 2.5 MHz.
Robert Scott
Real-Time Specialties |
Posted: Thu May 29, 2008 8:55 am |
setup_timer_2(T2_DIV_BY_1, 0, 1);
set_pwm1_duty(2L); // 50% duty cycle
