Other pins for RS232 possible?
spom
PostPosted: Thu May 29, 2008 6:20 am     Reply with quote
can I use other pins for using UART (RS232) instead of RX and TX?
SherpaDoug
PostPosted: Thu May 29, 2008 7:50 am     Reply with quote
For the hardware UART you must use the pins that Microchip has connected on the die. You can use a software UART on any pins, but then you have no interrupts.
RArtz
PostPosted: Thu May 29, 2008 8:03 am     Reply with quote
look up #use RS232 in the help file
