problem with RC5 remote code...
karthickiw
PostPosted: Wed May 28, 2008 11:43 am     Reply with quote
hai friends,
i try below code for decodes the RC5 remote code and send to rs232 port.. when press remote button, i don't got any data from rs232 port. please check the code and give the solution for problem.
#include <16F877a.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
int1 get_RC5(void);
#define IR_INPUT PIN_B0         // the infrared receiver has to be connected to an
                                // interrupt-pin!
#define IR_STATUS (!input(IR_INPUT))  // invert the signal from the infrared receiver
typedef struct
int8 data[2];
int8 state;
} rc5_struct;
rc5_struct rc5;
#int_EXT
EXT_isr()
   get_RC5();
int1 get_RC5(void)
   int16 tmp,t;
   int i;
   int1 inp;
   set_timer1(0);
   while(IR_STATUS==1);
   t=get_timer1();
   if ((t<400) || (t>800)) return 0;   // no RC5 code, abort decoding
   for (i=0;i<13;i++)
      inp=IR_STATUS;
      set_timer1(0);
      while (IR_STATUS==inp)
         t=get_timer1();
         if (t>800) return 0;   // no RC5 code, abort decoding
      tmp<<=1;
      if (inp==0) tmp++;
      set_timer1(0);
      while (get_timer1()<776);  // a simple delay would work here as well
   tmp=tmp | 0x3000;
   tmp=tmp & 0x37ff; // cut off togglebit
   rc5.data[0]=tmp & 0xff;  // device address
   tmp>>=8;
   rc5.data[1]=tmp & 0xff;  // command code
   rc5.state = 1;
   disable_interrupts(INT_EXT);
write_eeprom(0,rc5.data[0]);
          write_eeprom(1,rc5.data[1]);
   return 1;
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
write_eeprom(0,0Xff);
write_eeprom(1,0Xff);
   rc5.state = 0;
output_high(pin_b1);
      if(rc5.state==1)  // did we receive a valid RC5 - command?
printf("data[0] = %d ",rc5.data[0]);
printf("data[1] = %d ",rc5.data[1]);
         output_low(pin_b1);
         rc5.state = 0;
PostPosted: Wed May 28, 2008 11:59 am     Reply with quote
You copied that code directly from this website:
http://home.tu-clausthal.de/~dpor/files/rc5.c
At the bottom of his web page, he says this:
If you have any questions, just drop me a mail!
http://home.tu-clausthal.de/~dpor/rc5dekoder_eng.html
Why don't you do that ?
