John Goss Guest
| Direct bit manipulation |
Posted: Fri Sep 21, 2001 5:03 pm |
I want to assign Direct port pin manipulation using a structured name so that I may do the following:
PORTA = 0x55;
//or
PORTAbits.RA4 = HIGH
It is straightforward to assign the address to the port using the #byte directive. What I need to know is how then do I assign the structure "PORTAbits" to the same address as PORTA?
//PORTA
#byte PORTA = 0x05
extern struct {
unsigned RA0:1;
unsigned RA1:1;
unsigned RA2:1;
unsigned RA3:1;
unsigned RA4:1;
unsigned RA5:1;
unsigned RA6:1;
unsigned RA7:1;
} PORTAbits ;
#byte TRISA = 0x85
#define DDRA TRISA
___________________________
Original Post ID: 343 |
Tomi Guest
| Re: Direct bit manipulation |
Posted: Sat Sep 22, 2001 11:26 am |
<font face="Courier New" size=-1>Try the following:
extern struct {
unsigned RA0:1;
unsigned RA1:1;
unsigned RA2:1;
unsigned RA3:1;
unsigned RA4:1;
unsigned RA5:1;
unsigned RA6:1;
unsigned RA7:1;
} PORTAbits ;
#byte PORTAbits = 0x05
Usage:
PORTAbits.RA0 = 0;
PORTAbits.RA1= 1;
PORTAbits.RA2 = 0;
:=I want to assign Direct port pin manipulation using a structured name so that I may do the following:
:=PORTA = 0x55;
:=//or
:=PORTAbits.RA4 = HIGH
:=It is straightforward to assign the address to the port using the #byte directive. What I need to know is how then do I assign the structure "PORTAbits" to the same address as PORTA?
:=//PORTA
:=#byte PORTA = 0x05
:=extern struct {
:= unsigned RA0:1;
:= unsigned RA1:1;
:= unsigned RA2:1;
:= unsigned RA3:1;
:= unsigned RA4:1;
:= unsigned RA5:1;
:= unsigned RA6:1;
:= unsigned RA7:1;
:=} PORTAbits ;
:=#byte TRISA = 0x85
:=#define DDRA TRISA</font>
Original Post ID: 347 |
pha555 Guest
Posted: Sat Sep 22, 2001 2:18 pm |
I use a #include file that defines each register and each bit within a register;
#byte PORTA = 0x05
#byte PORTB = 0x06
#bit rb7 = PORTB.7
#bit rb6 = PORTB.6
#bit rb5 = PORTB.5
#bit rb4 = PORTB.4
#bit rb3 = PORTB.3
#bit rb2 = PORTB.2
#bit rb1 = PORTB.1
#bit rb0 = PORTB.0
This then permits simple manipulation of bits;
if (!rb7) // if at zero
or
rb0 = 1;
Peter H Anderson, <a href="http://www.phanderson.com/PIC/PICC/index.html" TARGET="_blank">http://www.phanderson.com/PIC/PICC/index.html</a>
:=PORTA = 0x55;
:=//or
:=//PORTA
:=extern struct {
:= unsigned RA0:1;
:= unsigned RA1:1;
:= unsigned RA2:1;
:= unsigned RA3:1;
:= unsigned RA4:1;
:= unsigned RA5:1;
:= unsigned RA6:1;
:= unsigned RA7:1;
:=} PORTAbits ;
Original Post ID: 349 |
Tomi Guest
Posted: Sun Sep 23, 2001 3:42 am |
Yes, it is simpler and better, but I think John is migrating from MicroChip's MPLAB-C/C17 and he doesn't like to modify his old program (the PortXBits structures are pre-defined in MPLAB-C header files).
:=I use a #include file that defines each register and each bit within a register;
:=#byte PORTB = 0x06
:=#bit rb7 = PORTB.7
:=#bit rb6 = PORTB.6
:=#bit rb5 = PORTB.5
:=#bit rb4 = PORTB.4
:=#bit rb3 = PORTB.3
:=#bit rb2 = PORTB.2
:=#bit rb1 = PORTB.1
:=#bit rb0 = PORTB.0
:=This then permits simple manipulation of bits;
:= if (!rb7) // if at zero
:=or
:= rb0 = 1;
:=Peter H Anderson, <a href="http://www.phanderson.com/PIC/PICC/index.html" TARGET="_blank"> <a href="http://www.phanderson.com/PIC/PICC/index.html" TARGET="_blank">http://www.phanderson.com/PIC/PICC/index.html</a></a>
:=:=I want to assign Direct port pin manipulation using a structured name so that I may do the following:
:=:=PORTA = 0x55;
:=:=//or
:=:=PORTAbits.RA4 = HIGH
:=:=It is straightforward to assign the address to the port using the #byte directive. What I need to know is how then do I assign the structure "PORTAbits" to the same address as PORTA?
:=:=//PORTA
:=:=#byte PORTA = 0x05
:=:=extern struct {
:=:= unsigned RA0:1;
:=:= unsigned RA1:1;
:=:= unsigned RA2:1;
:=:= unsigned RA3:1;
:=:= unsigned RA4:1;
:=:= unsigned RA5:1;
:=:= unsigned RA6:1;
:=:= unsigned RA7:1;
:=:=} PORTAbits ;
:=:=#byte TRISA = 0x85
:=:=#define DDRA TRISA
Original Post ID: 350 |
John Goss Guest
Posted: Sun Sep 23, 2001 5:01 pm |
Yes, this is what I am looking for. I am converting code over from Microchip's C18 compiler actually.
Can two variables be assigned to the same address without problems:
unsigned RA6:1;
unsigned RA7:1;
} PORTAbits ;
#byte PORTA = 0x05
Thanks,
John
:=<font face="Courier New" size=-1>Try the following:
:=extern struct {
:=unsigned RA0:1;
:=unsigned RA1:1;
:=unsigned RA2:1;
:=unsigned RA3:1;
:=unsigned RA4:1;
:=unsigned RA5:1;
:=unsigned RA6:1;
:=unsigned RA7:1;
:=} PORTAbits ;
:=#byte PORTAbits = 0x05
:=Usage:
:=PORTAbits.RA0 = 0;
:=PORTAbits.RA1= 1;
:=PORTAbits.RA2 = 0;
:=:=PORTA = 0x55;
:=:=//or
:=:=//PORTA
:=:=extern struct {
:=:=} PORTAbits ;
:=:=#define DDRA TRISA</font>
Original Post ID: 353 |
Tomi Guest
Posted: Mon Sep 24, 2001 12:30 pm |
Yes, you can use e.g. the following:
extern struct {
unsigned RA0:1;
unsigned RA1:1;
unsigned RA2:1;
unsigned RA3:1;
unsigned RA4:1;
unsigned RA5:1;
unsigned RA6:1;
unsigned RA7:1;
} PORTAbits ;
extern struct {
unsigned RA03:4;
unsigned RA47:4;
} PORTAnibbles ;
#byte PORTAnibbles = 0x05
#byte PORTA = 0x05
Disassembled samples:
.................... PORTAbits.RA1= 1;
01A3: BSF 05,1
.................... PORTAbits.RA2 = 0;
01A4: BCF 05,2
.................... PORTAnibbles.RA03 = 15;
01A5: MOVLW F0
01A6: ANDWF 05,W
01A7: IORLW 0F
01A8: MOVWF 05
.................... PORTA = 0xAB;
01A9: MOVLW AB
01AA: MOVWF 05
Original Post ID: 359 |
John Goss Guest
| Re: Direct bit manipulation - Are two structures possible? |
Posted: Tue Sep 25, 2001 11:39 am |
Well, I did the following, but when I try direct bit manipulation, it says "element not a member" ... It doesn't seem to like unions.. If I use just one structure, it works.
Can I use two different structures?
Thanks,
John
//PORTD--------------------
extern union {
struct {
unsigned RD0:1;
unsigned RD1:1;
unsigned RD2:1;
unsigned RD3:1;
unsigned RD4:1;
unsigned RD5:1;
unsigned RD6:1;
unsigned RD7:1;
struct {
unsigned PSP0:1;
unsigned PSP1:1;
unsigned PSP2:1;
unsigned PSP3:1;
unsigned PSP4:1;
unsigned PSP5:1;
unsigned PSP6:1;
unsigned PSP7:1;
} PORTDbits;
#byte PORTDbits = 0x08
#byte PORTD = 0x08
#byte PSP_DATA= 0x08
Original Post ID: 369 |
Tomi Guest
Posted: Tue Sep 25, 2001 12:18 pm |
Your problem is not CCS C specific; it is general C specific.
In your definition the union struct has two anonymous structures. Using a UNION means that you must say what part of the struct you use. In your code the compiler tries to find e.g. "PORTDbits..RD0" what is not an element, indeed (pay attention to double points!).
Use this:
extern union {
struct {
unsigned RD0:1;
unsigned RD1:1;
unsigned RD2:1;
unsigned RD3:1;
unsigned RD4:1;
unsigned RD5:1;
unsigned RD6:1;
unsigned RD7:1;
} IOPort;
struct {
unsigned PSP0:1;
unsigned PSP1:1;
unsigned PSP2:1;
unsigned PSP3:1;
unsigned PSP4:1;
unsigned PSP5:1;
unsigned PSP6:1;
unsigned PSP7:1;
} PSPPort;
} PORTDbits;
In my example you have a PSPPort and an IOPort structures; plus you have a union PORTDbits.
To access an element in a union you can type:
PORTDbits.PSPPort.PSP0 = 1;
PORTDbits.IOPort.RD0 = 0;
:=Well, I did the following, but when I try direct bit manipulation, it says "element not a member" ... It doesn't seem to like unions.. If I use just one structure, it works.
:=Can I use two different structures?
:=Thanks,
:=John
:=//PORTD--------------------
:=extern union {
:= struct {
:= unsigned RD0:1;
:= unsigned RD1:1;
:= unsigned RD2:1;
:= unsigned RD3:1;
:= unsigned RD4:1;
:= unsigned RD5:1;
:= unsigned RD6:1;
:= unsigned RD7:1;
:= struct {
:= unsigned PSP0:1;
:= unsigned PSP1:1;
:= unsigned PSP2:1;
:= unsigned PSP3:1;
:= unsigned PSP4:1;
:= unsigned PSP5:1;
:= unsigned PSP6:1;
:= unsigned PSP7:1;
:=} PORTDbits;
:=#byte PORTDbits = 0x08
:=#byte PORTD = 0x08
:=#byte PSP_DATA= 0x08
Original Post ID: 370 |
John Goss Guest
Posted: Tue Sep 25, 2001 1:54 pm |
Thank you!
:=Your problem is not CCS C specific; it is general C specific.
:=In your definition the union struct has two anonymous structures. Using a UNION means that you must say what part of the struct you use. In your code the compiler tries to find e.g. "PORTDbits..RD0" what is not an element, indeed (pay attention to double points!).
:=Use this:
:=extern union {
:=struct {
:=unsigned RD0:1;
:=unsigned RD1:1;
:=unsigned RD2:1;
:=unsigned RD3:1;
:=unsigned RD4:1;
:=unsigned RD5:1;
:=unsigned RD6:1;
:=unsigned RD7:1;
:=} IOPort;
:=struct {
:=unsigned PSP0:1;
:=unsigned PSP1:1;
:=unsigned PSP2:1;
:=unsigned PSP3:1;
:=unsigned PSP4:1;
:=unsigned PSP5:1;
:=unsigned PSP6:1;
:=unsigned PSP7:1;
:=} PSPPort;
:=} PORTDbits;
:=In my example you have a PSPPort and an IOPort structures; plus you have a union PORTDbits.
:=To access an element in a union you can type:
:=PORTDbits.PSPPort.PSP0 = 1;
:=PORTDbits.IOPort.RD0 = 0;
:=:=Well, I did the following, but when I try direct bit manipulation, it says "element not a member" ... It doesn't seem to like unions.. If I use just one structure, it works.
:=:=Can I use two different structures?
:=:=Thanks,
:=:=John
:=:=//PORTD--------------------
:=:=extern union {
:=:= struct {
:=:= unsigned RD0:1;
:=:= unsigned RD1:1;
:=:= unsigned RD2:1;
:=:= unsigned RD3:1;
:=:= unsigned RD4:1;
:=:= unsigned RD5:1;
:=:= unsigned RD6:1;
:=:= unsigned RD7:1;
:=:= struct {
:=:= unsigned PSP0:1;
:=:= unsigned PSP1:1;
:=:= unsigned PSP2:1;
:=:= unsigned PSP3:1;
:=:= unsigned PSP4:1;
:=:= unsigned PSP5:1;
:=:= unsigned PSP6:1;
:=:= unsigned PSP7:1;
:=:=} PORTDbits;
:=:=#byte PORTDbits = 0x08
:=:=#byte PORTD = 0x08
:=:=#byte PSP_DATA= 0x08
Original Post ID: 376 |
