Anyone know the difference?
mKm
PostPosted: Wed May 21, 2008 3:16 am     Reply with quote
Guys, could anyone please tell me the difference between the following statements:
[code]if(OpticalEncoder)
and
[code]if(input(OpticalEncoder))
[/code]Do these work the same way in MicroC?
Douglas Kennedy
PostPosted: Wed May 21, 2008 4:08 am     Reply with quote
Experiment. Put the statements in a test program that maybe blinks a led.
Somethings like learning to write have to be taught but many things can be discovered by experimenting. Coding involves a bit of teaching of syntax but if the statement compiles then experimenting is the better way to proceed.
If you have CCS C and micro C then test with both
Matro
PostPosted: Wed May 21, 2008 5:14 am     Reply with quote
In first case, "OpticalEncoder" is a C variable.
In second case, "OpticalEncoder" corresponds to a pin of the PIC that shall be defined through a #DEFINE directive.
Matro
rnielsen
PostPosted: Wed May 21, 2008 9:13 am     Reply with quote
Example 1:
int1 opticalencoder;
if(opticalencoder)
  do_stuff_here;
Example 2:
#define opticalencoder PIN_B0
if(input(opticalencoder))
  do_stuff_here;
That's the difference. Clear as mud?
Ronald
mKm
got it
PostPosted: Wed May 21, 2008 7:24 pm     Reply with quote
Even clearer... Smile ...Thank you...
