How to calculate the analog value from read_Adc()
Johnsecada
PostPosted: Mon May 19, 2008 4:35 pm     Reply with quote
hello
I has 8-bit adc . I read the digital value (int8) from read_adc() function. I want to
I found this statement analog_value = (float)(read_adc()*5/256)
my reference voltage is 5V.
How it works ?
read_adc()returns 8-bits binary number like this 00000001 . When we do *5 the binary number should be automatically convert to int.
Could someone tell me what actually happen here?
10x all
PostPosted: Mon May 19, 2008 5:03 pm     Reply with quote
Try this instead:
analog_value = (float)(my_read_adc()*5L)/256;
Johnsecada
I want to undestand how it works
PostPosted: Tue May 20, 2008 1:03 am     Reply with quote
Hello
i want to understand how it works ... Could you give me explanation.
What is 5L ?
RLScott
Re: I want to undestand how it works
PostPosted: Tue May 20, 2008 5:30 am     Reply with quote
Johnsecada wrote:
Hello
What is 5L ?
The default size of type int is 8 bits. If you have read_adc()*5/256, then all integer arithmetic will be conducted with 8-bit values. But read_adc() * 5 can overflow the 8-bit limit of 255. 5L means 5 "Long", so that 5 is treated as an int16. This forces read_adc() also to be promoted to int16 before the "*" operation, so there will be no overflow. Another way to express it is with a cast:
read_adc() * (int16)5
Robert Scott
Real-Time Specialties
Johnsecada
Great
PostPosted: Tue May 20, 2008 6:16 am     Reply with quote
10x very much Smile
