printf and lcdputc
rhodotron
printf and lcdputc
PostPosted: Sun May 18, 2008 12:48 pm     Reply with quote
Hello everybody !!
I am new in this forum and this is my first post. I have to say that this forum is very useful and I have found answers to 99.9% of my questions.
Presently, I am writing a program which takes values incoming into the R232 and then it sends them to a LCD.
My program is running well except that when I use the printf mixed with Lcd_putc, it send some random data on the RS232 port
 printf(lcd_putc,"%s",input_str);
As I am using hyperterminal and the function my_get_string, I have to send manually some backspace in order to send a valid set of data.
I am using a pcidem4 board.
Is there some body have any suggestions to improve this situation ?
thanks in advance for the help
Here is my code :
#include <18f1320.h>
#fuses NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP,H4,NOMCLR,NOFCMEN
#use delay(clock=16000000)
#include "flex_lcd.c"
#include "stdlib.h"
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B4)
#define BUFFER_SIZE 40
#define STRING_SIZE 11
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr()
    int t;
    buffer[next_in]=getc();
    t=next_in;
    if(next_in==next_out) next_in=t;           // Buffer full !!
BYTE bgetc()
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
void my_get_string(char* s, unsigned int8 max)
   unsigned int8 len;
   char c;
   --max;
   len=0;
   putc(0x0D);
   putc(8);
   putc(8);
   do
      c = bgetc();   // Call bgetc() instead of getc()
      if(c==8)
       {             // Backspace
         if(len>0)
            len--;
            putc(c);
            putc(' ');
            putc(c);
     else if ((c>=' ')&&(c<='~'))
      if(len<=max)
         s[len++]=c;
         putc(c);
   while(c!=13);
   s[len]=0;
char input_str[STRING_SIZE];
int32 value;
byte byte0,byte1,byte2,byte3;
float temps;
enable_interrupts(int_rda);
enable_interrupts(global);
lcd_init();
lcd_putc("\fAlpha pulsing ");
lcd_putc("\nIBA (C) ver 1.0");
output_High(PIN_B3);
delay_ms(2000);
lcd_gotoxy(1,1);
lcd_putc ("rate :          ");
   printf("\f\r\n");
   my_get_string(input_str, STRING_SIZE-1);
   disable_interrupts(int_rda);
   if (input_str[0]=='R')
      input_str[0]='0';
      value = atoi32(input_str);
      byte0 = make8(value,0);
      byte1 = make8(value,1);
      byte2 = make8(value,2);
      byte3 = make8(value,3);
      input_str[0]=' ';
      lcd_gotoxy(7,1);
      Lcd_putc("          ");
      lcd_gotoxy(7,1);
