1 second delay
John secada
1 second delay
PostPosted: Sun May 18, 2008 4:34 am     Reply with quote
Hello
I want to reach delay 1 second by using delay_ms(1000)
I know that it would not be exact 1 second and the processor would be occupied with the counting but it is good for my needs
The pic controller has CRYSTAL with 16 MHZ frequency and i use this code:
#include <16f88.h>
// #use delay(clock=20000000)
#use delay(clock=16 000 000)
void main(){
//set_tris_a(00000000b);
set_tris_b(0x00);
set_tris_a(0x00);
while(1){
output_b(0xFF);
output_b(0x00);
I cant reach 1 second with this code ... please tell me where is my error ?
Matro
PostPosted: Sun May 18, 2008 5:38 am     Reply with quote
#use delay(clock=16000000)
Without the spaces.
Matro
Johnsecada
the problem os not solve :(
PostPosted: Sun May 18, 2008 8:23 am     Reply with quote
I remove the spaces but this do not solve the problem ...
PostPosted: Sun May 18, 2008 8:41 am     Reply with quote
Try this program. It will blink an LED on pin B0. It uses the internal
oscillator instead of the external crystal. Try it, exactly as shown below.
#include <16F88.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
   output_high(PIN_B0);
   output_low(PIN_B0);
Johnsecada
PostPosted: Sun May 18, 2008 9:03 am     Reply with quote
The problem was in the simulate program ... not in the code ...
10x all for the help
