communication problem with RS232 and I2C
Jochen Kochner
PostPosted: Thu May 08, 2008 5:08 am     Reply with quote
I have a problem with the communication between RS232 and I2C.
If I'm using only the I2C communication, everything works fine, BUT if I only use the function kbhit() => I couldn't communicate anymore about I2C!
I'm using the PIC24HJ64GP206 with the following uinterface settings:
#use rs232 (STREAM=RS232STR, BAUD=19200, UART1, PARITY=N, BITS=8, STOP=1, TIMEOUT=100)
#use i2c (master, sda=SDA, scl=SCL, SLOW=100000, FORCE_SW, STREAM=I2CSTR)
What is wrong?
Regards
Jochen
drh
PostPosted: Thu May 08, 2008 8:09 am     Reply with quote
Try kbhit(RS232STR)
David
PostPosted: Fri May 16, 2008 4:14 am     Reply with quote
Thank's for your support.
I have used this function but without success.
I think it is a timing problem because I made a very complicated (asin, acos, etc.) calculation and in this case I think the i2c bus hang-up itself.
Now I have to find this error problem!
Regards
Jochen
PostPosted: Fri May 16, 2008 4:41 am     Reply with quote
On the I2C, _you_ are the master, so control the timing. Anything you do, in terms of pauses etc. in the main code, should not hang the I2C. If it does get 'hung', it probably implies an external problem like noise on the line, or that your slave is not properly handling the ACK/NACK sequencing when it replies.
Have you actually used the kbhit, _with the stream identifier_, as opposed to just calling kbhit on it's own?.
Basically, there is nothing 'wrong' in the setups as given, but there could be problems in how you then use these.
Jochen Kochner
PostPosted: Tue May 27, 2008 4:12 am     Reply with quote
Thank's for the answer!
In the moment everything works fine! Very Happy
BUT I have decrease the BAUD_RATE of the RS232 from 19200 to 2400 and I don't know why it works! Sad
Do you have a idea what I can do to increase the BAUD_RATE to 19200 and to have a stable I2C bus?
Regards
Jochen
