SPI on PIC18F4580 Master and PIC16F877A Slave
quangphongit
PostPosted: Thu May 15, 2008 10:38 am     Reply with quote
I'm trying to demo SPI interface between 18F4580 is Master and 16F877A is slave, used 4 wire: SDI, SDO, SCK and nSS.
This is my code for Master:
#define SS_LOW (output_low(pin_A5)) //pin RA5 conected to nSS in 16F877A
#define SS_HIGH (output_high(pin_A5))
   byte rs;
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
   delay_ms(3000);
   SS_LOW;
   spi_write(0x55);
   rs = spi_read();
   SS_HIGH;
   led_perform(1);       // led on and off in 200ms when transmitting is completed
//And this my code for slave
   byte kq;
   setup_spi(SPI_SLAVE);
   kq = spi_read();
   delay_us(100);
   output_d(kq);     //output kq on port D
   spi_write(0);
   /*if(spi_data_is_in())
   led_perform(1);             //led on and off one time
   if(SSPBUF==0x55)
   led_perform(3);          //led on and off three time
I compiled this code completed, and loaded it in the PIC.
But the slave didn't receive any bit from Master, had not perform any thing (led on-off 0 time, and port D perform nothing)
Please tell me why???
Thanks guys.
PostPosted: Thu May 15, 2008 11:46 am     Reply with quote
Look at the CCS example files for an SPI slave:
c:\Program Files\picc\Examples\Ex_spi_slave.c
c:\Program Files\picc\Examples\Ex_spi.c
This thread has code that demonstrates an SPI slave
but it's done using one board (because it's a demonstration).
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
quangphongit
Experiented
PostPosted: Thu May 15, 2008 11:47 pm     Reply with quote
My kit was run very well!
The problem is, after init the SPI interface, should add delay_ms(100) and after each spi_read() should add delay_ms(1). I tried and succeeded.
the code here
//MASTER
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);   // TODO: USER CODE!!
   SS_LOW;
   rs = spi_read(0x55);
   delay_ms(1);
   SS_HIGH;
   if(rs==0x33)
      led_perform(1);
   kq = spi_read();
   delay_ms(1);
   spi_write(0x33);
   if(kq==0x55)
         led_perform(1);
This code is running well, SPI transfer well.
I post this reply to show the basic transfer of SPI for who don't know this, as me yesterday.
Thanks guys
art
2 wire SPI
PostPosted: Tue Feb 02, 2010 4:48 am     Reply with quote
Has anybody implemented a 2-wire SPI in a PIC16F877A or in any microcontroller as the master? I need some info for this because my slave IC which is an energy IC is configured as 2 wire SPI. All I need is to supply serial clock from the PIC to the slave so that I can get the data. The data comes from the slave.
Is it possible that a PIC can be configured as 2 wire SPI using only the SCK and SDI pin? Will the PIC (master) still supply a serial clock if it is configured as 2 wire SPI?
