How to change the clock frequency in a existing project?
se07860
PostPosted: Thu May 15, 2008 8:42 am     Reply with quote
i have a home-made board with a 16F876A-I/SP and a xtal of 4MHz and i want to change it for an 20MHz xtal. The question is... What must i do to change the clock frequency from 4 to 20MHz? I don't know how to do it because I've tried to do this but the software doesn't work.
Thanks for your help
RLScott
Re: How to change the clock freqüency in a existing project
PostPosted: Thu May 15, 2008 8:54 am     Reply with quote
Well, if you just replaced the 4MHz crystal with a 20MHz crystal, the first thing you need to do is to change the configuration fuses for the oscillator type from XT to HS. 20MHz is too high to work reliably with the XT configuration.
The next thing you have to do is to examine all the aspects of your software that are dependent on the clock speed. This includes the serial baudrate, if you are using a serial port, timers, etc. Some of these things can be done automatically by the CCS compiler if you specify the new frequency using the #USE DELAY command. But you should not count on this happening without your thinking it through yourself. Without getting into the details of your application, it is impossible to say everything that might need to be done to accommodate the 20MHz crystal.
Robert Scott
Real-Time Specialties
se07860
PostPosted: Thu May 15, 2008 9:05 am     Reply with quote
Job done and working.
Thanks for your answers to my qüestion (i think one answer has disappeared Shocked )
PostPosted: Thu May 15, 2008 9:25 am     Reply with quote
I deleted my answer as it was a double post.
