hobiadami
Joined: 17 Oct 2006 Posts: 35 Location: City of Concrete
rtos and watchdog |
Posted: Thu May 15, 2008 6:07 am |
Hello all,
I've searched the forum posts for an answer to my question but there doesn't seem to exist any.
I've designed a solar powered remote temperature sensor by using 16f628 and DS1822. To give it a try, i've used the CCS RTOS for the first time. The program works fine, reading the temp from DS1822 and printing it on a 5x7 dot matrix led display (which is located sideways) by using smaller fonts that 2 can fit side by side on the display.
the power is supplied from a very small solar panel, stored on a 1.2V nimh AA type cell. The 1.2v is switched up to around 3-5v to run the micro.
the power is very unstable, so i'm having reset issues. The MCLR is enabled and connected to VDD by a 4k7 resistor.
To have a proper reset, i've used the watchdog in my previous designs and they perfectly work for years.
But in the RTOS, the system seems constantly resetting itself and restart_watchdog() seems to be useless. my wd period is 2304ms.
is there something wrong with the RTOS-WATCHDOG couple? _________________ www.endtas.com |
Wayne_
Posted: Thu May 15, 2008 7:12 am |
So you have a system which worked for years, so what is the difference ?
You are trying to use the RTOS system and it does not work!
You say you have reset issues BUT if the hardware is the same as the system that worked for years then this should be OK ! NO ?
Your original system, if suffering from reset issues may have been written to account for it and save/load data for reset recovery.
An RTOS system does not recover from a reset, it resets.
Using the Watchdog is only good for recovering from hung software (stuck in a loop) due to bad coding or a hardware problem. This does not resolve reset issues unless it is the watchdog that is causing the reset, inwhcih case you need to look at your software to find out what part of it is taking up soooo much time.
You need to try and find out if it is the watchdog which is causing the reset or as I suspect the hardware.
If it is the watchdog then you have a loop or interrupt which does not allow for the watchdog to be reset. Are you using the RTOS correctly. I am assuming it is not an interrupt driven RTOS but a task driven one. Each task will need to reset the watchdog or release RTOS control to another task which does kick the WD before the WD resets. |
hobiadami
Posted: Fri May 16, 2008 1:29 am |
Quote: | Each task will need to reset the watchdog |
does it need to be that way? i didnt know that and i've simply created a task, which has the job of refreshing the watchdog only. the task works once in every 2 seconds.
my other products are 12F675 based solar light controllers and they also have the issue on first power up. I've used them with WD for years. They generally don't start properly when the sun is down, due to the time it takes the power circuitry to begin generating stable voltages. So the program hangs in someplace doing unpredictable light on offs. but no problem it only takes 2.3 seconds to WD to reset things and start the circuit's normal running, after the voltage gets to acceptable levels.
The difference is the code which is written in CCS RTOS. Surely i'm not using the tools of the RTOS properly somehow, making a mistake. maybe i should post my code. WD is constantly resetting the micro, so it is somehow not properly refreshed. If i'll try to put a refresh_wd statement to each task and test. _________________ www.endtas.com |
Matro Guest
Posted: Fri May 16, 2008 2:16 am |
An RTOS should provide its own "software" watchdog that should be used instead of the hardware watchdog of the PIC.
Matro |
Wayne_
Posted: Fri May 16, 2008 2:22 am |
"so a programmer must be careful with how much processor time a task uses for execution"
Unless you specify the max parameter in the #use TASK settings then a task may take longer to execute than the RTOS rate. You either need to ensure your task yields processing to the RTOS to allow the WD kicker to run or you need to kick the WD in the task.
If you specify max then the compiler will work out the timings of the task and inform you of a problem.
It seems also possible that another task may start running just before the WD task is set to run. If this task then takes too much time (which is valid) the WD will be late and it will have reset.
You will need to check your timing.
BUT, you may still find it is not the WD resetting the device. You can check the reset cause by checking a flag on the pic. The first reset should be power on, reading the flag at the next reset will tell you if it was the WD.
Do any of your tasks have infinite loops in them ?
Do any of your tasks have large loops or delays ?
1 option, Double the rate of the WD task to see if this helps. |
