Is the MMC fdriver code in PICC OK ??
arunb
PostPosted: Tue May 13, 2008 11:48 pm     Reply with quote
MCU: 18F4620, 18F4550
Compiler: PCH 4.073
I intend to use a 18F4620 or 18F4550 for a MMC based project. I am interested in using the MMC driver in the PICC folder.
Kindly advise if there are any known bugs for this driver.
I am using a 7 pin RS MMC card, can the driver be used for this kind of a memory card ??
thanks
arunb
Pret
PostPosted: Thu May 15, 2008 3:45 am     Reply with quote
Read this post http://www.ccsinfo.com/forum/viewtopic.php?t=33375&highlight=.
arunb
RE
PostPosted: Thu May 15, 2008 4:36 am     Reply with quote
Thanks for the link.
arunb
asmallri
PostPosted: Thu May 15, 2008 6:20 am     Reply with quote
You might like to check out my drivers. http://www.brushelectronics.com/index.php?page=software#SDUTIL
If you are not using a FAT file system then these PICs are both fine. If you are intending to use a FAT and write files then the PIC18F4620 with its larger RAM is a better option.
Regards, Andrew
arunb
RE:
PostPosted: Thu May 15, 2008 8:15 am     Reply with quote
The system I am designing scans input ports (90 in all) and logs the status to the memory (MMC card). The system would not do any other file operations..
Is a FAT system justified for this kind of a system ??
thanks
arunb
asmallri
PostPosted: Thu May 15, 2008 8:41 am     Reply with quote
The main reason for using a FAT is if you want to be able to remove the SD/MMC card and have it written to or read from a PC or other device using the FAT file system.
Regards, Andrew
