How do I pass a pin definition through a function.
delene
PostPosted: Tue May 13, 2008 9:08 am     Reply with quote
I have several pins
#define Reader1 pin_b0
#define Reader2 pin_b1
#define Reader3 pin_b2
Currently each pin has its own function. I would like to make it so that I have one function that can use all 3 pins...
Something like
ReadTemp(Reader1);
ReadTemp(Reader2);
ReadTemp(Reader3);
The only thing is I don't know how to declare the variable in the function void ReadTemp(xxxxx); I don't know what to put in the xxxx to allow the pin number to be used...
Any help is greatly appreciated..
PostPosted: Tue May 13, 2008 10:11 am     Reply with quote
int16.
So something like:
int16 ReadTemp(int16 pin) {
   output_high(pin);
   return(what_you_want);
This is only supported in the latter compilers (older version 3 compilers only supported constants for the pin definitions). Routines to allow a variable to access a pin, for the older compilers, have been posted here on several occasions.
delene
PostPosted: Tue May 13, 2008 10:17 am     Reply with quote
THANK you thank you thank you...
I will give a try in the morning, and hopefully it will work...
Thanks for the help
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed May 14, 2008 1:49 am     Reply with quote
P.S. That works only with v4. However, I guess most users of v3 knows about this limitation.
Read the label, before opening a can of worms.
PostPosted: Wed May 14, 2008 2:00 am     Reply with quote
I do mention this limitation. PCM programmer, and myself (amongst others), have posted code to access the pins with a variable, for the V3 compilers.
