testing osscon for stable
PicCoder
PostPosted: Mon May 12, 2008 6:59 pm     Reply with quote
I am just starting to convert a SourceBoost C program to CCS and so have a few questions that are probably elementary to most of you.
My first question has to do with the first lines of code in my SourceBoost program starts:
osccon = 0b01110000; //Setup internal oscillator for 8MHz
while(osccon.2 == 0) ; //Wait for frequency to stabilize
I used the project wizard to create my first project and it generated this line in main:
setup_oscillator(OSC_8MHZ|OSC_INTRC);
but it doesn't wait for the frequency to stabilize. In Help it says that setup_oscillator sometimes returns a value that can be tested for stability and I see that in the PIC16F88 header file there is something called OSSCON_STATE_STABLE. So, on a lark I gave this a try:
while(setup_oscillator(OSC_8MHZ|OSC_INTRC) != OSC_STATE_STABLE);
It compiles with a warning that operator precedence might not be as intended, which I don't really understand.
I also tried this:
while(OSSCON.2 == 0) ;
but got another warning, this time telling me that OSSCON is always false. So, I guess there is a different way of addressing bit 2 of the OSSCON register, right?
So, what is this the right way of doing this very common operation?
n-squared
PostPosted: Mon May 12, 2008 9:17 pm     Reply with quote
Try the following:
#byte     OSCCON    = 0xFD3
#bit        STABLE      = OSCCON.2
 while (!STABLE);
Good luck
Noam
Every solution has a problem.
