error in stepper code
ferrousduke
PostPosted: Mon May 12, 2008 9:26 am     Reply with quote
Its about microstepping control of stepper motor.. but there's some error and i can not seem to get out of the cycle.. I'm not really good at logic.. please help. full step angle 4 degrees. microstepping it by 1/16 PWM logic on full step.
#if defined(__PCH__)
#include <18F452.h>
#include <input.c>
/*//int i;
#define button_cnt1_pressed output_high(PIN_B0)
#define button_cnt2_pressed output_high(PIN_B1)
#define forward_1 output_high(PIN_D0)
#define reverse_1 output_low(PIN_D0)
#define forward_2 output_high(PIN_D1)
#define reverse_2 output_low(PIN_D1)
halfstepping(void);
fullstepping(void);
reversestepping(void);*/
#define led_on output_low(PIN_A2);
   int i, full_step, pwm[8] = {50,95,140,177.5,207.5,232.5,245,250};
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   set_tris_b(0);
   set_tris_a(0);
   output_high(PIN_B3);
   output_high(PIN_B2);
   setup_timer_2(T2_DIV_BY_1, 250, 1);
   full_step = 0;
   while(full_step != 1)
      set_pwm1_duty(250);
      for(i=0;i<8;i++)
      set_pwm2_duty(pwm[i]);
      delay_us(1000);
      set_pwm2_duty(250);
      for(i=7;i>=0;i--)  \\Getting stuck here..
      set_pwm1_duty(pwm[i]);
      delay_us(1000);
      output_low(PIN_B3);
      set_pwm2_duty(250);
      for(i=0;i<8;i++)
      delay_us(1000);
      set_pwm1_duty(250);
      for(i=7;i>=0;i--)
      delay_us(1000);
      full_step++;
      led_on;
RLScott
Re: error in stepper code
PostPosted: Mon May 12, 2008 12:33 pm     Reply with quote
ferrousduke wrote:
..but there's some error and i can not seem to get out of the cycle..
Please explain what cycle you can't get out of.
Robert Scott
Real-Time Specialties
PostPosted: Mon May 12, 2008 2:10 pm     Reply with quote
In CCS the integers are unsigned by default, this means 'i' will never become smaller than 0 and hence you don't get out of the loop.
A possible solution is:
      for(i=8;i>0;i--)  \\Getting stuck here..
      set_pwm1_duty(pwm[i-1]);     // note the '-1'
      delay_us(1000);
Apply the same change to the other loop as well.
You can not use floating point numbers in an integer array. The values will be truncated, so 177.5 becomes 177, 207.5 becomes 207, etc.
ferrousduke
PostPosted: Mon May 12, 2008 3:05 pm     Reply with quote
thanks ckiestra.. I tried the correction.. but some strange problem is coming up.. before my motor turned a full step in simulation. i.e. 4 degrees.. After the correction in code, it stops at 3.5 degrees..
PostPosted: Mon May 12, 2008 5:45 pm     Reply with quote
Sorry, I don't know anything about microstepping and can't help you. Maybe someone else can jump in?
RLScott
PostPosted: Tue May 13, 2008 7:29 am     Reply with quote
How do you know it stops at 3.5 degrees? It looks to me like your test program goes through 16 microsteps that gradually transition from PWM1=250, PWM2=50 to PWM1=50, PWM2=250. To me that defines one full step. Now if you were to continue on to the next full step you would change the polarity of PWM1 by toggling RB3 and then do another 16 microsteps where you go from PWM1=50, PWM2=250 to PWM1=250, PWM2=50. Then the third full step would be executed by reversing the polarity of PWM2 by toggling RB2, etc. It looks like you are one the right track.
Robert Scott
ferrousduke
PostPosted: Tue May 13, 2008 7:47 am     Reply with quote
yup I am planing exactly on what you said. I am using proteus ISIS for simulating the code. I used bipolar stepper motor with step angle 4 degrees.. Now, before the code was corrected, it simulated full step of 4 degrees. but now its coming to 3.5 degrees. the problem was only to get rid of the loop so that I can switch RB3 and go to another full step and so on.
RLScott
PostPosted: Tue May 13, 2008 9:23 am     Reply with quote
I still don't understand how you know it is going only 3.5 degrees. Perhaps the simulation is at fault. All I know is, when you run a real motor, it will go through one full step when you do your 16 microsteps.
Robert Scott
ferrousduke
PostPosted: Sat May 17, 2008 12:45 pm     Reply with quote
Hello
can you please check whats wrong with the code? If you have proteus ISIS installed on ur comp, I can send the simulation files and source.
regards.
ferrousduke
PostPosted: Sat May 17, 2008 2:00 pm     Reply with quote
ferrousduke wrote:
Hello
regards.
Yup I have solved that problem. It was a little bit of sequencing problem. I have encountered one more problem while toggling switch CNT1 and CNT2. Logic seems all ok but code does not work. I'm not good at C. Please help.
code:
#include <18F4550.h>
#include <input.c>
/********* ÎÏÐÅÄÅËÅÍÈß ÈÑÏÎËÜÇÓÅÌÛÕ ÍÀÈÌÅÍÎÂÀÍÈÉ *********/
#define led_on output_high(PIN_E0)
#define led_off output_low(PIN_E0)
#define CNT1 PIN_D0
#define CNT2 PIN_D1
void change_polarity(void);
void indicate(void);
   int i, full_step, pwm[8] = {0,50,95,140,177.5,207.5,232.5,245};
   set_tris_d(0);
   output_high(CNT1);
   output_high(CNT2);
   full_step = 0;
   //**ÖÈÊË ÏÎËÍÎÃÎ ØÀÃÀ**
      //****** ÏÅÐÂÛÉ ÏÎËÓØÀÃ *******
      set_pwm1_duty(250); //**ÓÑÒÀÍÎÂÊÀ "ØÈÌ 1" ÍÀ 100% ÄÎ ÇÀÂÅÐØÅÍÈß ÏÎËÓØÀÃÀ**
      delay_us(200);
      for(i=1;i<=8;i++)
         //**ÏÎÂÛØÅÍÈÅ ØÈÌ 2**
         set_pwm2_duty(pwm[i-1]);
         delay_us(200);
      //****** ÂÒÎÐÎÉ ÏÎËÓØÀÃ *******
      set_pwm2_duty(250); //**ÓÑÒÀÍÎÂÊÀ "ØÈÌ 2" ÍÀ 100% ÄÎ ÇÀÂÅÐØÅÍÈß ÏÎËÍÎÃÎ ØÀÃÀ**
      delay_us(200);
      for(i=8;i>0;i--)
         //**ÏÎÍÈÆÅÍÈÅ ØÈÌ 1**
         delay_us(200);
      ++full_step; // Ñ×ÅÒ×ÈÊ ÏÎËÍÛÕ ØÀÃÎÂ
      change_polarity();
      delay_us(200);
      for(i=1;i<=8;i++)
         //**ÏÎÂÛØÅÍÈÅ ØÈÌ 1**
         delay_us(200);
      set_pwm1_duty(250);
      delay_us(200);
      for(i=8;i>0;i--)
         //**ÏÎÍÈÆÅÍÈÅ ØÈÌ 2**
         delay_us(200);
   if(CNT1 == 1 && CNT2 == 1)
      output_low(CNT1);
      output_high(CNT2);
      if(CNT1 == 0 && CNT2 == 1)
      output_low(CNT1);
      output_low(CNT2);
         if(CNT1 == 0 && CNT2 == 0)
         output_high(CNT1);
         output_low(CNT2);
            if(CNT1 == 1 && CNT2 == 0)
            output_high(CNT1);
            output_high(CNT2);
PostPosted: Sat May 17, 2008 3:45 pm     Reply with quote
First... Why do you still have the floating point items in the integer array that I told you to get rid of?
#define CNT1 PIN_D0
#define CNT2 PIN_D1
This is not going to work. CNT1 and CNT2 are hard coded values while you want them to return the pin status. To achieve that you can change the code to
if ( (input_state(CNT1) == 1) && (input_state(CNT2) == 1) )
But this approach could introduce a problem known as the 'read-modify-write problem'. Writing a value to the output and reading it back again might give wrong results if the capacitance on the line is high. With a large capacitance on the line it can take a long time for the voltage to reach the desired output level so you are reading back the wrong value.
Best is to introduce an extra variable to remember the output state:
void change_polarity()
  static int8 OutState = 0;   // Note the 'static' keyword to make the variable is remembered in between function calls.
  OutState++;
  if (OutState >= 4)
    OutState=0;
  switch(OutState)
    case 0:
      output_high(CNT1);
      output_high(CNT2);
    case 1:
      output_low(CNT1);
      output_high(CNT2);
    case 2:
      output_low(CNT1);
      output_low(CNT2);
    case 3:
      output_high(CNT1);
      output_low(CNT2);
