Im implementing USB in a mobile device. Using the PLL would draw too much current so I was hoping to just use a 24MHz crystal without the PLL enabled.
If I understand the datasheet correctly, I can use a 24Mhz crystal for USB low-speed operation. Would the USB work correctly using a 24Mhz crystal with PLL disabled?
Ideally I would like to run the device using the INTRC at 32khz to perform certain operations, then when the USB is plugged in (ill use usb-sense with an interrupt) switch over to the 24MHz crystal.
Being a mobile device I need to save as much power as possible when the USB is not connected.
thanks
Posted: Mon May 12, 2008 3:12 pm
Look at this table in the PIC data sheet:
TABLE 2-5: OSCILLATOR CONFIGURATION OPTIONS FOR USB OPERATION
The 5th entry shows that you can use a 24 MHz crystal or oscillator
(in HS or EC mode, respectively) to provide the PIC's clock frequency.
There is a note in the PLL Division column that says this configuration
is only valid for low-speed USB operation.
