Guest3 Guest
printf format |
Posted: Sun May 11, 2008 3:49 am |
I'm receiving this data per my serial pc connection but am getting wrong formating on my LCD and i can read just the first string (0xC1).
I know i have to include the space but don't know how
example:
0xC1 0xB3 0x21 0x2B 0x51 0x1B 0x2B
i'm using the:
printf(lcd_putc,"%c",PT);
result on LCD:
0xC ( without 1 and other data)
One more thing. If i can correct the formating and if i can get all data, then what should i do to erase all that data (after 0x2B) so i can receive new and changed one ? |
Posted: Sun May 11, 2008 11:51 am |
thank you for reply.
I construct my question a bit wrong.
What i mean was, how to know when is the last character.
I know for now that i will get cca 8 "packages" of hex data and after last one i have to clean the lcd. I can not check for the last character because they are different each time so i guess i have to make some array and then make the check when the array is full ?.
What do you think, why i cant read all of the data ? |
Posted: Sun May 11, 2008 12:21 pm |
Quote: | 0xC1 0xB3 0x21 0x2B 0x51 0x1B 0x2B
i'm using the:
result on LCD:
0xC ( without 1 and other data) |
To display data bytes in Hex format, use the "%x" format specifier.
To put a space between the bytes, use "%x ". |
Guest3 Guest
Posted: Sun May 11, 2008 1:00 pm |
OK. but...
char c;
lcd_init();
pt = getc();
printf(lcd_putc,"%x",pt);
INPUT:
0x21
0x3C
test
OUTPUT:
0x2
0x3
tes
Why ? |
Posted: Sun May 11, 2008 1:03 pm |
Post a complete test program. Post the #include, #fuses, #use delay()
and #use rs232() statements. Post the main(). Don't post the LCD
driver. I don't need to see it. Just post the #include statement for it.
Post all your variable declaration statements.
The program should be short.
It must also be compilable with no errors. |
Guest3 Guest
Posted: Mon May 12, 2008 11:32 am |
Code: | #include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#include "lcdDriver.c"
char pt;
lcd_init();
pt = getc();
Posted: Mon May 12, 2008 11:57 am |
Your code has a 1 second delay in your receiving loop.
While this delay is in occurring, you are not reading characters from
the hardware UART's receive buffer. If new characters come in
and you don't read them (because of the delay), you will get an
over-run error and the characters will be lost.
What is the spacing (in time) between the incoming bytes ? |
Guest3 Guest
Posted: Mon May 12, 2008 2:42 pm |
Quote: | What is the spacing (in time) between the incoming bytes ? |
To better answer this question i will tell you which program am using.
It's advanced serial port monitor and the connection is set to 9600, none, 8, 1. I was start to thinking that this is because unregistered version of this program, but now i know its not.
I removed the delay part but the output is the same.
![Question](images/smiles/icon_question.gif) |
Posted: Mon May 12, 2008 3:04 pm |
When you use "%x" or "%x ", you are sending out 2 or 3 characters
for every one that comes in. This can cause a loss of incoming
characters because the code has to wait in a loop for the UART
transmitter buffer to become ready to accept another character.
Look at the Ex_sisr.c example file. It shows how to use the #int_rda
interrupt to receive the characters during an interrupt and to put them
in a buffer. Then your main() program can check to see if characters
are available in the buffer, and get them from there.
When you use this method, the receiving of characters is not affected
by delays in the main program. That's because it's done by interrupts.
Here is the file location:
Guest3 Guest
Posted: Wed May 14, 2008 10:59 am |
void bputc(char c) {
short restart;
int ni;
restart=t_next_in==t_next_out;
t_buffer[t_next_in]=c;
ni=(t_next_in+1) % T_BUFFER_SIZE;
while(ni==t_next_out);
t_next_in=ni;
if(restart)
enable_interrupts(int_tbe);
lcd_init();
enable_interrupts(global);
printf(lcd_putc,(bputc,"Test"));
do {
delay_ms(2000);
printf(lcd_putc,(bputc,"Buffered:\r\n"));
} while (TRUE);
Im not 100% sure how is this working but am testing it.
Just two questions...
Why putc function and not getc ?
How to get right LCD output. Now i get Buffered: -:- , regardless what i enter. |
