Port E problem? 18F4525
KU5D
PostPosted: Mon May 12, 2008 9:11 am     Reply with quote
Guys,
This seems strange to me, or I'm missing something simple. I have a device that among many other things uses onewire to read an iButton. Initially, I was using pin_C4 as the one-wire pin, and the thing worked flawlessly. However, due to other hardware considerations I moved from C4 to E2, which is of course one of the analog input pins. I'm wondering if I have to specifically set the direction for this pin when writing to and reading from the one wire. On the C port, I didn't have to do this.
Now, along with the onewire, I have 7 analog inputs that I need to read, so here's how I set up my analog inputs:
#define  ADC_CLOCK_INTERNAL 0X07
#define  AN0_TO_AN6 0x08
//initialize adc input channel and set up ports
inputChannel = 0;
setup_adc_ports (AN0_TO_AN6);                               //set AN0 thru AN6 analog
setup_adc (ADC_CLOCK_INTERNAL);
This should exclude E2 and I think it should be now a digital input.
This is what the .lst file shows:
.................... setup_adc_ports (AN0_TO_AN6);                               //set AN0 thru AN6 analog
7D04:  MOVF   FC1,W
7D06:  ANDLW  C0
7D08:  IORLW  08
7D0A:  MOVWF  FC1
I'm wondering two things. 1. is the compiler setting this up correctly, or 2. do I have to explicitly set the data direction on port E when using it as an input or output?
Ah yes, my compiler version is 3.249.
Confidence is the feeling you have right before you fully understand the situation...
PostPosted: Mon May 12, 2008 10:21 am     Reply with quote
Are you using standard i/o mode (the default mode), and are you
using CCS pin i/o functions ?
If so, the compiler should set the correct TRIS automatically.
KU5D
PostPosted: Mon May 12, 2008 10:29 am     Reply with quote
Can I do that and still use analog ins 0 thru 6, and have what was AN7 (pin E2) as a digital I/O for the onewire? Right now, I am not doing #USE STANDARD IO. I am using standard CCS pin funtions such as output_bit...
PostPosted: Mon May 12, 2008 10:53 am     Reply with quote
It's the default mode. You don't have to specify it. It's automatically
in effect unless you override it by using #use fast_io or #use fixed_io.
In the test program shown below, the following code is generated for
the output_bit() function. It does set the TRIS. So I think your problem
is somewhere else. I don't think it's the TRIS, unless you're doing
something else besides using output_bit().
... output_bit(PIN_E2, 1);
0014:  BSF    LATE.2
0016:  BCF    TRISE.2
#include <18F452.h>
KU5D
PostPosted: Mon May 12, 2008 11:14 am     Reply with quote
OK, the output seems to be working, at least it doesn't look any different on a 'scope than it does on Port C. However, this is a onewire device that I read, so I suspect that once I send the command from Pin_E2, I need to turn it around and make it an input. Can I do this by pin, or do I have to set the direction for the entire port? I still need to keep my analog inputs AN0 thru AN6.
I didn't include #fuses in the previous post. Here they are (don't think this is the issue):
#device ADC=8
#device HIGH_INTS=TRUE
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
#use delay(clock=10000000)
PostPosted: Mon May 12, 2008 11:17 am     Reply with quote
The CCS pin i/o function that changes a pin to an input is the
output_float() function. Here is the code from the test program
shown below:
0014:  BSF    LATE.2
0016:  BCF    TRISE.2
... output_float(PIN_E2);
0018:  BSF    TRISE.2
#include <18F452.h>
KU5D
PostPosted: Mon May 12, 2008 11:24 am     Reply with quote
OK, here's my onewire code. There's a function at the bottom that is called from main() when a timer runs out and sets the getOneWire flag. It's called "DoOnewire". As I said earlier, this works fine if I define the OneWire as pin C4. It breaks if I use E2. The array called AnalogIns[] may be a bit misleading...it isn't the ADC, it's a buffer used to ship this stuff over a radio link.
void onewire_reset()                                        // OK if just using a single permanently connected device
   output_low (OneWire);                                    // pull 1-wire low for reset pulse
   delay_us(500);
   output_float(OneWire);                                   // float 1-wire high
   delay_us(500);
//================== onewire_write() =========================
void onewire_write(int data)
int count;
   for (count=0; count<8; ++count)
      output_low(OneWire);
      delay_us( 2 );                                        // pull 1-wire low to initiate write time-slot.
      output_bit(OneWire, shift_right(&data,1,0));          // set output bit on 1-wire
      delay_us(60);
      output_float(OneWire);                                // set 1-wire high again,
      delay_us( 2 );                                        // for more than 1us minimum.
//====================== read1wire() ===================================
//This function reads the 8 -bit data via the 1-wire sensor. */
//Parameters:
//Returns: 8-bit (1-byte) data from sensor
int8 onewire_read()
int8 count, data;
      delay_us( 2 );                                        // pull 1-wire low to initiate read time-slot.
      output_float(OneWire);                                // now let 1-wire float high,
      delay_us( 8 );                                        // let device state stabilise,
      shift_right(&data,1,input(OneWire));                  // and load result.
      delay_us(120);
return( data );
// DoOneWire()
DoOneWire()
int8  oneWireCnt;
int8  busy = 0;
disable_interrupts(GLOBAL);
   onewire_reset();
   onewire_write(0x33);
   while (busy == 0)
      busy = onewire_read();
   onewire_reset();
   for(oneWireCnt = 8; oneWireCnt >0; oneWireCnt--)
      AnalogIns[oneWireCnt + 7] = onewire_read();
   getOneWire = FALSE;                                   //clear the get me flag
   if(inDebugMode)
      fprintf(PC,"iButton: %X %X %X %X %X %X %X %X \r",AnalogIns[8],AnalogIns[9],AnalogIns[10],AnalogIns[11],
               AnalogIns[12],AnalogIns[13],AnalogIns[14],AnalogIns[15]);
PostPosted: Mon May 12, 2008 11:46 am     Reply with quote
Do you know for sure that Pin E2 is free ? What if it's connected to a
pull-down resistor or some other circuit ?
I suggest trying a different pin than E2. See if another pin will work.
KU5D
PostPosted: Mon May 12, 2008 12:23 pm     Reply with quote
PCM,
Try this on for infuriating:
2 identical iButton sockets; 1 wired for the old board using C4 and the other wired for the new board using E2. All made up nice and neat with heatshrink, and good connectors.
Problem: ground wire separated inside of heatshrink on socket for new board. I've chased this for hours and wasted not only my time, but yours as well.
My apologies,
many thanx
