bittersweet
ds18b20 and ds1302 rtc problem |
Posted: Sun May 11, 2008 11:45 am |
Hi;
i am using ds18b20 temperature sensor and ds1302 rtc but have some problems...
firstly,minute part is increasing after 90 seconds and sometimes minute is decreasing...so rtc is awful
secondly,ds18b20 temperature sensor shows 180-200 celcius degree. when i heat it with my hand degree is increasing...
ds18b20.c code
int onewire_read()
int count, data;
for (count=0; count<8; ++count)
output_low(ONE_WIRE_PIN);
delay_us( 2 ); //Sensördem okuma işlemi içinl 1-wire sıfıra çekilir.
output_float(ONE_WIRE_PIN); //1-wire bir yapılır,
delay_us( 8 ); // Sensörün kendine gelmesi beklenir,
shift_right(&data,1,input(ONE_WIRE_PIN)); // sonuc bilgisi alınır.
delay_us( 120 ); //Okuma işlemi zamanı doldurulur.
return( data );
float ds1820_read()
int8 busy=0, temp1, temp2;
signed int16 temp3;
float result;
onewire_reset();
onewire_write(0xCC);
onewire_write(0x44);
while (busy == 0)
busy = onewire_read();
onewire_reset();
onewire_write(0xBE);
temp1 = onewire_read();
temp2 = onewire_read();
temp3 = make16(temp2, temp1);
result = (float) temp3 / 2.0;
delay_ms(200);
return(result);
main code
#include <16F877A.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
#define RTC_SCLK PIN_c4
#define RTC_IO PIN_c5
#define RTC_RST PIN_c3
#include <ds1302.c>
#include <ds18b20.c>
#include <lcd.c>
#use rs232 (baud=600, rcv=PIN_C7)
float temp;
int saniye,dakika,saat,gun,ay,yil,haftanin_gunu;
temp = ds1820_read();
rtc_get_time(saat,dakika,saniye);
rtc_get_date(gun,ay,yil,haftanin_gunu);
lcd_gotoxy(1,1);
printf(lcd_putc,"%02d/%02d/20%02d ",gun,ay,yil);
lcd_gotoxy(1,1);
printf(lcd_putc,"%02d:%02d:%02d %3.1f%cC",saat,dakika,saniye,temp,223);
Posted: Sun May 11, 2008 11:50 am |
Work on only one problem at a time. First work on the RTC problem.
Remove all code for the ds18b20. Also remove all connections to it
on the PIC. When you get the RTC to work perfectly, then add the
code and connections for the ds18b20 and work on it. |
bittersweet
Posted: Sun May 11, 2008 12:23 pm |
@ PCM programmer
I've already tried only rtc code and it doesnt work, the problem is same with only rtc code and rtc with ds18b20. And I dont know how to correct them.
If u can help me I'll be satisfied... |
Posted: Sun May 11, 2008 12:31 pm |
Quote: | I've already tried only rtc code and it doesnt work |
Then work on it until it does work. Don't add more code and more
hardware devices until you get the first one working. |
bittersweet
Posted: Sun May 11, 2008 1:00 pm |
ok then my fist problem is how I correct ds1302 problem, I dont understand where is wrong?
#include <ds1302.c>
#include <lcd.c>
setup_timer_1(T1_DISABLED);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
lcd_init();
rtc_init();
rtc_set_datetime(9,6,8,2,11,31);
lcd_gotoxy(1,1);
lcd_gotoxy(1,1);
printf(lcd_putc,"%02d:%02d:%02d ",saat,dakika,saniye);
Posted: Sun May 11, 2008 1:12 pm |
1. Post a list of all connections to the DS1302 chip. Post the part
number, manufacturer, and value of all external components that are
connected to the DS1302.
This webpage has photos of a DS1302 circuit. They have a 32.768 KHz
watch crystal and a "Super cap" connected to the DS1302. Do you have
those components also ?
http://ghmicro.com/index.php/projects/14-clocks/11-pic-16f877-a-ds1302-simple-clock
2. What pins on the PIC are used for the LCD ? Post a list. |
bittersweet
Posted: Sun May 11, 2008 1:47 pm |
the connections on DS1302:
X1-X2 32.768kHz
RST pin c3
I/O pin c5
SCLK pin c4
but the difference between my circuit and the circuit at the link is the capacity on Vcc2. i wired 3 volts here as shown in the datasheet. do i have to use capasity? |
Posted: Sun May 11, 2008 2:18 pm |
Do you have Vdd and ground connected to the DS1302 ?
What is the Vdd voltage on the DS1302 and on the PIC ? |
bittersweet
Posted: Sun May 11, 2008 2:20 pm |
of course I connected Vdd 5v gnd 0V, PIC's Vdd is 5v, too. |
Posted: Sun May 11, 2008 2:27 pm |
I looked in my parts box and I have a ds1302. I am going to hook it up
and finish this thing.
Post your compiler version. It's given at the top of the .LST file.
The .LST file is in your project directory. |
bittersweet
Posted: Sun May 11, 2008 2:31 pm |
This is the compiler version,
CCS PCM C Compiler, Version 3.182, 16465 |
Posted: Sun May 11, 2008 3:17 pm |
I was able to make it work. It required one change, as shown in the
code below. After that change is made, then it displays this on the lcd:
Quote: |
09/06/2008
11:31:00
The seconds increment from 00 to 01, 02, 03, etc.
In the code below the lcd_gotoxy() statement must have coordinates
of (1, 2) as shown in bold below. If you change it to (1, 2) it should work.
Quote: |
lcd_gotoxy(1,1);
lcd_gotoxy(1, 2); // *** Change this line
bittersweet
Posted: Sun May 11, 2008 3:31 pm |
thanks alot, but I must use 2nd line for another application, cant I write date and clock on first line... |
Posted: Sun May 11, 2008 3:33 pm |
But what happens if you test the code as shown in my post ?
Does it start working ? |
bittersweet
Posted: Sun May 11, 2008 3:39 pm |
yes I tried and it is working:) thanks alot but is there any way to write them on the same line |
