Unreliable Interrupt
jack0218
PostPosted: Sat May 10, 2008 10:55 pm     Reply with quote
I have a device that, among other things, uses the Timer0 interrupt to operate a one second duration LED "metronome" at a period of 5s. The "metronome" itself works as it is supposed to, but sometimes has an initial delay of around 1.5 minutes before it begins its cycle. This only happens occasionally, happens more often for some chip writings than others, and can sometimes be resolved by turning the power off and on once or a few times. I think that this may be due to a problem with initialization or some related topic, but the consistency of the delay is concerning. I would just like this function to be reliable; thanks in advance for your help.
#include "18F2321.h"
#fuses INTRC_IO,NOFCMEN,NOIESO,NOPUT,NOBROWNOUT,NOWDT,CCP2C1,NOPBADEN,LPT1OSC,NOMCLR,NOSTVREN,NOLVP,NOPROTECT,NOCPB
#use delay(clock=8000000)
#INT_TIMER0
int metronome(int two_Hz_timing_interrupt)
two_Hz_timing_interrupt=two_Hz_timing_interrupt+1;
if (two_Hz_timing_interrupt==1)
     output_high(PIN_A5);
else if (two_Hz_timing_interrupt==3)
     output_low(PIN_A5);
else if (two_Hz_timing_interrupt==10)
    two_Hz_timing_interrupt=0;
return two_Hz_timing_interrupt;
int two_Hz_timing_interrupt=0;
SETUP_TIMER_0(RTCC_DIV_16|RTCC_INTERNAL);
ENABLE_INTERRUPTS(INT_TIMER0);
ENABLE_INTERRUPTS(GLOBAL);
SET_TIMER0(0);
while (TRUE)
{***other unrelevant stuff***}
PostPosted: Sun May 11, 2008 12:43 am     Reply with quote
There are several problems:
1. An interrupt service routine (isr) can't have a variable passed to it as
a function parameter. It has to be a global variable instead.
A global variable will be visible to both the isr and the code in main().
2. An isr can't return a value.
The code below shows the required changes in bold:
int two_Hz_timing_interrupt = 0; // Add this line, in this location.
#INT_TIMER0
void metronome(void) // No parameters or return values allowed
output_low(PIN_A5);
return two_Hz_timing_interrupt; // *** Delete this line
int two_Hz_timing_interrupt=0; // Move this line above the isr
SET_TIMER0(0); // Move this line up to here.
// Do all initialization of hardware modules before you enable ints.
while (TRUE)
