Multiple #FUSES statements?
barryg
PostPosted: Fri May 09, 2008 1:01 pm     Reply with quote
I haven't been able to find anything definitive in the manual, but the implication is that you can have successive #fuses statements without one cancelling the next. Some of these processors have some pretty long fuse lists, if you specify them all. Does anyone know for sure if you can say, like:
#fuses HS,NOWDT,PUT
#fuses NOLVP
#fuses STVREN
As usual, I can test this (with some effort decoding the hex file), but I'd rather see something more official from the compiler maker. Thanks.
PostPosted: Fri May 09, 2008 1:55 pm     Reply with quote
The CCS wizard does this. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=34712
rnielsen
PostPosted: Fri May 09, 2008 1:56 pm     Reply with quote
You can have multiple fuses in the same line, just separated by commas or individual fuse statements like you have listed. I'm not sure about having a combination of each but I would imagine that it will work. I haven't tested that one out. I usually have them all in the save #FUSE statement.
Ronald
