rtc problem
bittersweet
rtc problem
PostPosted: Fri May 09, 2008 1:44 am     Reply with quote
I want to write date on lcd with ds1302, but I only see
D:00/00/2000
H:00:00:00
Here are the codes
#include <16F877A.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
#include <lcd.c>
#include <DS1302.c>
byte saniye, dakika, saat, gun, ay, yil, haftanin_gunu;
{setup_psp(PSP_DISABLED);
 setup_spi(SPI_SS_DISABLED);
 setup_timer_1(T1_DISABLED);
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 setup_CCP1(CCP_OFF);
 lcd_init();
 rtc_init();
 rtc_set_datetime(9, 06, 8, 4, 10, 18);
  rtc_get_time(saat, dakika, saniye);
  rtc_get_date(gun, ay, yil, haftanin_gunu);
  printf(lcd_putc, "\fD:%02d/%02d/20%02d", gun, ay, yil);
  switch(haftanin_gunu)
  {case 1: printf(lcd_putc, "PAZ"); break;
   case 2: printf(lcd_putc, "PZT"); break;
   case 3: printf(lcd_putc, "SAL"); break;
   case 4: printf(lcd_putc, "CRS"); break;
   case 5: printf(lcd_putc, "PRS"); break;
   case 6: printf(lcd_putc, "[spam]"); break;
   case 7: printf(lcd_putc, "CTS"); break;
   printf(lcd_putc, "\nH:%02d:%02d:%02d", saat, dakika, saniye);
what must I do?
treitmey
PostPosted: Fri May 09, 2008 7:36 am     Reply with quote
Is your DS1302 chip wired up like this?
RTC_SCLK ----->PIN_B1
RTC_IO -----> PIN_B3
RTC_RST -----> PIN_B2
bittersweet
PostPosted: Fri May 09, 2008 1:52 pm     Reply with quote
hi again,
i cope with this problem at proteus but in hardware part date and time is 01/01/2000 00:00...i reset the circuit,it started to show the real time as i set in software.But a few seconds later it turned to show 01/01/2000 00:00 again...
how can i correct the real time?
here's the code:
#define RTC_SCLK PIN_c4
#define RTC_IO   PIN_c5
#define RTC_RST  PIN_c3
#include <ds1302.c>
#include <lcd.c>
#use rs232 (baud=600, rcv=PIN_C7)
char x;
int say1=0;
int say2=0;
int saniye,dakika,saat,gun,ay,yil,haftanin_gunu;
float temp;
void read()
{ x=getc();}
void fivebyte1()
         if(getc()==0xff)
          {say2++;
          if(say2>=5)
          {say2=0;
           read();
           break;}
        else {say2 = 0;
        break;}
void fivebyte0()
   if(getc()==0x00)
   { say1++;
          if(say1>=5)
           {say1=0;
            fivebyte1();
            break;}
            else say1 = 0;
   setup_adc(ADC_OFF);
   setup_CCP2(CCP_OFF);
   lcd_init();
   rtc_init();
   rtc_set_datetime(9,6,8,2,11,31);
 fivebyte0();
 switch(x)
  case 'a':
  lcd_gotoxy(1,2);
  printf(lcd_putc, " TRAFIK YOGUN   ");
  case 'b':
  lcd_gotoxy(1,2);
  printf(lcd_putc, " TRAFIK AKICI      ");
  case 'c':
  lcd_gotoxy(1,2);
  printf(lcd_putc, "TRAFIK COK YOGUN ");
  case 'd':
  lcd_gotoxy(1,2);
  printf(lcd_putc, " YOL BOS     ");
 rtc_get_time(saat,dakika,saniye);
 rtc_get_date(gun,ay,yil,haftanin_gunu);
 lcd_gotoxy(1,1);
 printf(lcd_putc,"%02d/%02d/20%02d",gun,ay,yil);
 printf(lcd_putc," %02d:%02d:%02d",saat,dakika,saniye);
