| Help I've lost my function |
Posted: Mon Apr 21, 2008 10:14 am |
Basically,
I have code which compiles just fine in 4.069 but after upgrading to 4.071 I am getting error 53 expecting function name. This error is not being generated by my own personally defined functions but for the predefined functions of the compiler:
output_high, output_x, disable_interrupts
I can uninstall and revert to 4.069, which I have but my coworkers are compiling on 4.071 so this is not a good idea for a long term fix. Any ideas or quick fixes.
Thanks in advance |
Matro Guest
Posted: Mon Apr 21, 2008 10:54 am |
We need the complete error message and a few line range around the line triggering the error.
Matro |
sirWally
Posted: Mon Apr 21, 2008 12:50 pm |
*** Error 53 "source\Peripheral.c" Line 26(4,12): Expecting Function name
code
void ConfigPorts(void)
//clear all the ports
output_a(0x00); //clear ports <- this is 4,12
output_b(0x00);
output_c(0x00);
output_d(0x00);
output_e(0x00);
output_f(0x00);
output_g(0x00);
it also creates the same error for several other points in the program of the same type all to do with compiler defined functions. The functions that generate this error are also not consistent. The same error will occur over and over again but each time it will happen to different compiler defined functions within my code. Again, version 4.069 works just fine so I am inclined to say this is a compiler issue. My coworker is doing just fine in 4.071 so there is probably sometype of conflict occuring on my own PC with the compiler. I am running windows XP, have done a new install of 4.071 after deleting all configuation files and all relevent registry keys that are easily associated with CCS. Perhaps I should be addressing this to the support group at CCS but I was hoping that someone else has had this problem and has found a quick solution to it such as recreating a config file or changing a hidden registry value.
Thanks |
Posted: Mon Apr 21, 2008 1:19 pm |
1. Post your PIC.
2. Post a short test program that incorporates that code.
The program should show the #include, #fuses, #use delay(), main(),
etc. It should be compilable. Compile the program and confirm that
it shows the error, before you post it. |
Posted: Wed May 07, 2008 12:42 pm |
PICC 18F6627
| Code: | #include <18F6627.h>
#device ADC=8 ICD=TRUE
#use delay(clock=7372800,RESTART_WDT)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7,ERRORS,RESTART_WDT)
#fuses HS,WDT16384,NOBROWNOUT,BORV27,PROTECT,NODEBUG
#zero_ram |
This problem is not consistent. I can compile the code base just fine in 4.069 but when using 4.071 or 73 I get the same type of error. Different code bases compile fine in version 4.073 even though they do have similar calls to proprietary functions.
At times, if I recompile the code several times, up to ten, in a row then on the last attempt the compilation succeeds. This is not a consistent error, but is damn frustrating. |
| Still more |
Posted: Thu May 08, 2008 12:38 pm |
Error:
***Error 53 "source\9522a2.c" Line 764(10,16): Expecting function name
for (i=2; i<cfg_bytes; i++)
if (!((i >= 0x12) && (i <= 0x51)))
Val1 = read_eeprom(i);
printf(S_Putc,"%c", Val1);
LATChecksum ^= Val1;
CalcdChecksum += Val1;
printf(S_Putc,"%c", LATChecksum); // this is line 764
CalcdChecksum += LATChecksum;
printf(S_Putc,"%c", 0x04);
CalcdChecksum += 0x04;
printf(S_Putc,"%c",(int)(CalcdChecksum >> 8));
printf(S_Putc,"%c",(int)CalcdChecksum);
If I comment out that line and recompile it works just fine. I then add it back in and I get the same error. Note also that I had made no changes to this particular file after my last successful build of the code. I made changes in other files, then tried to compile and am now getting this type of issue again. |
| even more |
Posted: Thu May 08, 2008 12:44 pm |
If I change the order of the code from:
CalcdChecksum += LATChecksum; |
To:
| Code: | CalcdChecksum += LATChecksum;
printf(S_Putc,"%c", LATChecksum); |
It then compiles just fine. This change does not effect my results so that is fine but this is a real problem.[/code] |
| More More More |
Posted: Thu May 08, 2008 12:53 pm |
I then tried something else, I replaced the previous code with the following:
printf(S_Putc,"%c", 0x04); // Line 763
printf(S_Putc,"%c", 0x04); // Line 764
printf(S_Putc,"%c", 0x04); // Line 765
printf(S_Putc,"%c", 0x04); // Line 766
printf(S_Putc,"%c", 0x04); // Line 767
printf(S_Putc,"%c", LATChecksum); // Line 768
printf(S_Putc,"%c",(int)CalcdChecksum); |
I then get the Errors as follows:
***Error 53 "source\9522a2.c" Line 763(10,16): Expecting function name
***Error 53 "source\9522a2.c" Line 765(10,16): Expecting function name
***Error 53 "source\9522a2.c" Line 766(10,16): Expecting function name
***Error 53 "source\9522a2.c" Line 767(10,16): Expecting function name
***Error 53 "source\9522a2.c" Line 768(10,16): Expecting function name
Once again I change the code and place the line
above the printf's as such
And it compiles just fine. I hope this makes my issue a little more clear. |
Posted: Thu May 08, 2008 1:03 pm |
Is this a large program ? In multiple files ?
This may be something that CCS has to look at. Email support and ask
if you can send them a Zip of your program. Ask if they can find the
problem. Give them your user reference number so they know you own
the compiler. |
| again with a lost function |
Posted: Thu May 15, 2008 4:52 pm |
in this example I have a call to delay_ms which, when the code is compiled, generates the same type of error.
delay_ms(150);
*** Error 53 "source\J12J21.c" Line 1544(7,15): Expecting function name
I then replace the above call with the following
delay_ms(150);delay_ms(150);
and it compiles just fine. I then remove one of the calls and the error reoccurs.
This is very frustrating |
Posted: Thu May 15, 2008 5:16 pm |
| Quote: | | Again, version 4.069 works just fine so I am inclined to say this is a compiler issue. |
Then go back to using 4.069, if necessary.
| Quote: |
My coworker is doing just fine in 4.071 so there is probably sometype of conflict occuring on my own PC with the compiler. |
Has he tried to compile your project on his machine ? If not, try it. |
Posted: Mon Jun 16, 2008 12:15 pm |
This is still on going.
It is a large program with multiple files. My coworker gets the same problem with the code as well. I am really begining to hate this as I can spend up to an hour before getting a successful build. I am not joking. I really think that this means the CCS is a no go for us any longer, it is simply to costly to waste this much time in just getting the program to build. |
