Unsupported Struct
bkidney
Unsupported Struct
PostPosted: Mon Apr 19, 2004 6:26 am     Reply with quote
I am trying to debug a piece of code in MPLAB (using an ICE 2000) but in my watch list I am getting the message "Unsupported Struct" for sec[] array.
typedef struct
int16 end;
int16 cost;
} Sectioned;
typedef struct
Sectioned sec[5];
} SecCosts;
typedef struct
int16 cost;
} Unsectioned;
typedef union
Unsectioned usec;
SecCosts seced;
} Rate;
typedef struct
int16 base;
int16 tax;
BYTE type;
Rate rate;
INT32 check;
} CostTable;
Is this a limitation of the compiler, or have I done something wrong? (My compiler version is Version 3.181).
Thanks,
Brian Confused
PostPosted: Tue Apr 20, 2004 2:01 am     Reply with quote
Which version of MPLAB are you using?
In the release notes for v6.50 I noted the following under the new features:
"Watch windows support pointers, structure members, enum symbol values."
Max
PostPosted: Thu Sep 23, 2004 7:24 am     Reply with quote
also I have problems with watch and to see structure with mplab 6.61:
typedef struct
bit enablea:1;
bit enableb:1;
bit enablec:1;
bit stop:1;
bit flagdelay:1;
bit run:1;
unsigned int16 delay;
unsigned int16 delay_t;
} my_struct;
my_struct in_out[MAX];
watch MPLAB 6.61:
address symbol name value
00B4 - in_out
[0] orted Struct
[1] orted Struct
[2] orted Struct
[3] orted Struct
Help thanks Crying or Very sad
ChrisW
Same Prob Here...
PostPosted: Wed May 07, 2008 1:58 pm     Reply with quote
I'm also getting "Unsupported Struct" messages in the MPLAB Watch window (MPLAB 8.00, CCS 4.057).
Does anyone know a fix for this?
Many thanks,
Chris Very Happy
#device PIC18f4550
struct sTest {
   unsigned char Data;
} gTest[2];
void main (void){
iigruntii
BUMP ME TOO
PostPosted: Tue Jul 06, 2010 2:03 pm     Reply with quote
Can someone on the CCS staff please confirm this as an issue? I have the same problem. Watch window says "Unsupported Struct" when I try to create a struct array. Is this a limitation or is it a bug?
Example code:
typedef struct {
UCHAR write;
UCHAR readBuff[4];
UCHAR readCounter;
UCHAR *readDest;
UCHAR device;
}SPIMSG;
static SPIMSG SpiQueue[8];
PostPosted: Tue Jul 06, 2010 2:24 pm     Reply with quote
Three things:
1) You are reporting a problem in MPLAB, a Microchip product and not from CCS.
2) Always post the version numbers of your tools (CCS and MPLAB)! It might be a known problem.
3) Read the forum rules and the message on the right top of each page:
Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
I tried it in MPLAB v8.46 and CCS v4.077 and get correct values in the mouse over window.
The Watch window works too.
