Problem with Multiple ADC channels
pandu.ranganadh
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Wed May 07, 2008 8:13 am     Reply with quote
Hi to all,
I am using the bellow details of version.
CCS C Compiller 6.0
PCM version 3.170b
PCH version 3.170b
IDE version 3.36
MPLAB IDE version v8.02
I have a problem with accessing multiple ADC Channels in PIC16F877,
and i am using PIC older version demo board.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010072&part=DM163022
#include <16F877.H>
#device adc=10
//#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=16000000)
#include "flex_lcd.c"
int16 adc_value;
float volts,a=10.25;
lcd_init();
setup_adc_ports(RA0_ANALOG);
set_adc_channel(0);
//set_adc_channel(1);
delay_us(20);
adc_value = read_adc();
/* The formula for ADC conversion is */
/* ADC result = (ADC Digital output value * V.reff)/2^no.of ADC channels */
/* -> 1023.0 or 1024.0 represents the 10 bit ADC, inorder to get acurate */
/* result that value should be maintain as float. */
/* -> 5 represents the V reference voltage for ADC is 5V */
/* -> " adc_value " represents the o/p of the ADC, inetially is was binary */
/* but " read_adc(); " function converts that value in to integer. */
/* -> Inoder ot get float result answer should be convert(Typecast) in to */
/* float. */
volts = (float)(adc_value * 5)/1023.0; // This is the fixed formula
//lcd_putc("\f Output \n");
printf(lcd_putc,"\f %3.4f Volts\n",volts);
Its working for Channel-0 only. How to use remaining channels.
Please check and resend code.
Bye
Thanking you.
densimitre
PostPosted: Wed May 07, 2008 8:18 am     Reply with quote
setup_adc_ports (other ports)
Bye
pandu.ranganadh
PostPosted: Wed May 07, 2008 8:23 am     Reply with quote
Thank you for sending reply,
I have done that job as
setup_adc_ports(ALL_ANALOG); or any of other, then its not working, There is no display on LCD.
Bye
Thanking you.
densimitre
PostPosted: Wed May 07, 2008 9:17 am     Reply with quote
First set_adc_channel, then read_adc()
to read other channel you mut set the correct channel and read it after..
Bye
PostPosted: Wed May 07, 2008 11:37 am     Reply with quote
Most of the A/D pins are already used for other purposes on your board.
It uses pins A1, A2, and A3 for the LCD, and pin A4 is used for switch S2.
Pin A0 is connected to a trimpot.
The only A/D pins that you can use are these:
pin   channel
RA5   AN4
RE0   AN5
RE1   AN6
RE2   AN7
