Gerhard
Joined: 30 Aug 2007 Posts: 144 Location: South Africa
Clearing lcd characters |
Posted: Tue May 06, 2008 2:58 pm |
I have the following line on the LCD program.
Code: | lcd_gotoxy(1,2);
printf(lcd_putc,"%3.0f", x); |
However the value of x goes over 1000 which causes the value of x to be displayed as say 1000 but if x goes back below 1000 the value should be shown as say 980 but it shows the value of 9800. How is it possible to fix this as i have looked all over the net but cant find a solution other than to use a bunch of if statements in the lcd function or to clear the line each time before i write something to it but that causes the lcd to flicker. |
Humberto
Posted: Tue May 06, 2008 3:38 pm |
Remember that you are writing in a RAM like adjacent cells memory.
If you want to write a 4 digit value like 1000, lcd_putc() start writting in the location
pointed by gotoxy(). If you write 980, it start writing in the same location like 1000,
but it only writes 3 digits. The next digit still keep the '0' of the previous 4 digits value,
and it shows you 9800.
Try this:
printf(lcd_putc,"\f");
lcd_gotoxy(1,2);
Humberto |
Gerhard
Posted: Tue May 06, 2008 4:30 pm |
Thanks Humberto
What i did wrong is in the way i display the characters.
I should have realised that printf(lcd_putc,"%3.0f", x); will work correctly until i reach 1000 then the %3.0f will not work anymore and i should have changed it to %4.0f.
Thanks for the advice |
Gerhard
Posted: Tue May 06, 2008 4:56 pm |
I am trying to make the display neater and PCM Programmer refered me to a site which indicates how to do it but ccs complains about a invalid format if i use the - sign such as in the following example. Is there another way to align the numbers to the left?
Code: | printf("Printing 3.141592 using %%9.3f displays %9.3f\n", x);
printf("Printing 3.141592 using %%-9.3f displays %-9.3f\n", x);
Printing 3.141592 using %9.3f displays 3.142
Printing 3.141592 using %-9.3f displays 3.142 |
Posted: Tue May 06, 2008 5:08 pm |
The program shown below has the following output:
1.230
1.230
1.230
1.230
1.230
Code: | #include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
float value;
value = 1.23;
printf("%9.3f \n\r", value);
printf("%8.3f \n\r", value);
printf("%7.3f \n\r", value);
printf("%6.3f \n\r", value);
printf("%5.3f \n\r", value);
Gerhard
Posted: Tue May 06, 2008 5:27 pm |
That way it still fills the values from the right which shows a value in a format such as:
I need it to display as follows
Meaning it should start filling at the left side such as the minus sign does on the website you refered me to.
